Injen Intake 6SP Coupe RD1992
Old Jul 8, 2004 | 01:32 PM
bkingston's Avatar
Florida G35 Club, Premier Member
Just bought this intake from a distributer on ebay, however it is missing one of the two vibra-mounts that it says it is supposed to come with in the parts list. I contacted the seller and he says only the RD1990 for the automatic needs 2 the 6 spd only needs one. Is this true, or is he flat out lying to me. Any help would be greatly appreciated.
Thanks in advance,
Bryan
Old Jul 8, 2004 | 06:14 PM
bkingston's Avatar
Re: Injen Intake 6SP Coupe RD1992
Anybody?
Old Jul 8, 2004 | 07:43 PM
Rever's Avatar
I have the Injen CAI on my 6mt and it came with the 2 rubber bushings. I've never heard of the 6mt only needing 1. If you'd like I can take pics of the install to show you the rubber bushings. Let me know.
04' G coupe/TB/Prem/Sport/Nav/35% Tint/Injen CAI/Clear corners/V5 Plenum/GroundingGear/Nismo caps
Plates: 1REVER1
Old Jul 8, 2004 | 07:52 PM
bkingston's Avatar
Thanks for your help, the package was factory sealed, just missing a rubber mount, bolt, washers and this guy wants nothing to do with the responsibility of replacing them.
Old Jul 8, 2004 | 10:08 PM
dragon_long's Avatar
you only need one
Old Jul 9, 2004 | 12:07 AM
Gsedan35's Avatar
I had the Injen on my 6MT, I'm positive it only used one, though my memory could be wrong.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 9, 2004 | 12:10 AM
GurgenPB's Avatar
I also used ONE, and I used to havethe 1990. You do NOT need two.
Gurgen
Old Jul 9, 2004 | 08:08 AM
bkingston's Avatar
Thanks for all the help. I called Injen's technical support yesterday and there response was, if the part list say there should be two then you need two, inspirational at best. So for those in this post, in the instructions when it says to that the first step is to remove the stock m6 bolt and screw the vibra mount into the pre tapped hole in the frame, and then in step 5 it says to screw the vibra mount into the pre tapped hole to the side of the intake manifold, which step do you skip.
Thanks,
Bryan
Old Jul 9, 2004 | 05:43 PM
b0hr's Avatar
I only got one with mine, I kinda retrofitted the one closer to the filter with the old hardware from the airbox. But mine was sealed too and only came with one
andresito7
Aug 1, 2015 04:53 AM
newg37
Jul 26, 2015 09:32 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
