Water in my donor motor. Can it be saved?
Old Apr 28, 2009 | 12:40 AM
skandalous1's Avatar
I am in the middle of swapping out motors. The donor motor was left outside under a "waterproof" cover. To my surprise there was water all over the engine after a recent rain. To make matters worse the intake manifold was not on the motor and water seeped in through the valves. I have blown most of the water out with a compressor but am wondering if there are any other precautions I can take to save the motor? I have not turned it over at all. Any suggestions? Thanks in advance
Old Apr 28, 2009 | 12:42 AM
elayman's Avatar
get it really hot to evaporate the water
Old Apr 28, 2009 | 07:03 PM
superchargedg's Avatar
It should be okay as long as it was not running when it injested the water.I would pull the plugs and put a little marvel mystery oil(get it at pepboys,autozone) in each cylinder first and crank it over as it will expell allmost all the water.Next i would change the oil and run the engine for about 30 minutes and change the oil again and you should be fine.
Old Apr 28, 2009 | 10:13 PM
Thanks for all the advice. It appears that the motor is fine. No water came out but now the car wont start due to no fuel and spark . Immobilizer maybe?
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
Detailed Image
Sep 28, 2015 07:04 AM
