Is there a Infiniti mechanic here??
Old Apr 28, 2009 | 02:51 PM
Heinz's Avatar
I need some help.
I have a little problem, with my 2004 G35 Coupe 6MT.
I went to a Nissan garage to do a service on the car, and they also used a instrument called "Consult 2" to delete some error codes, due to earlyer battery problem.
After he deleted the errors, he also opened a menu called BCM, on this "Consult 2" and checked the settings, and he obviously changed some settings, which i found out some days later when the trunk button on the remote controll did not work, and the auto on/off headlamps did not work, probably also alot more.
I then drowe back to this Nissan garage, where one other guy opened the BCM menu to fix this, but this guy says that all the settings now are deleted, and has to be re programmed.
He says that this setup is a program that can be downloaded from Infiniti to his Consult, and reprogram the car.
I can also post the settings, as it was from original, and how it is today, if that is of any help.
Can anyone helpe me whit this, or help me tell me who to contact.
Old Apr 28, 2009 | 03:06 PM
Heinz's Avatar
The Nissan dealer will do all the work for free, but the biggest problem is that the program does not exist on this Consult anymore,
My car comes from USA, and here in Europe there is NO Infiniti dealers, so it has to be downloaded from an Infiniti workshop in USA.
Old Apr 28, 2009 | 08:32 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry about your issues, but how cool is it to be the ONLY G35 in Scandanavia? Are you sure you have the only 1? Poor Scandanavian people, they don't know what they're missing!!!!!!!!
Old Apr 30, 2009 | 07:00 PM
bythabay's Avatar
lol
Old May 2, 2009 | 08:53 PM
stickytech's Avatar
i am an infiniti tech.he probably changed the configuration in the bcm.there is no bcm reprogramming.he can fix it.there are several modes and it will take a lot of guesses with a service manual
Old May 2, 2009 | 09:00 PM
bythabay's Avatar
ahh, post #1, welcome to the forums!
Old May 2, 2009 | 09:39 PM
stickytech's Avatar
figures it would be trying to help someone.
Old May 4, 2009 | 06:16 AM
Heinz's Avatar
Is there any way to reset, or set back the BCM to factory settings, without using the Consult?
Old May 4, 2009 | 08:25 PM
stickytech's Avatar
no.unless it is a new one.once its configured it stays like that.you could try disconnecting the bcm,but i doubt it will work
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
rezendvous420
May 31, 2020 01:26 PM
snic09
Nov 8, 2017 01:46 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
