Switching engine oil
I've been getting my car serviced at the dealership (2004 model) and have had only penzoil syntec 5w 30. I'm getting a service done at another shop that specializes in infinitis and lexuses but they use valvoline instead. Does anyone use valvoline? Should I stick with the penzoil?
I use mobil1 5/30 but have heard the valvoline may be superior. There's a million threads, but there's one somewhere that states along the lines of mobil1, penzoil, castrol etc etc all burn through about half a quart per oil change (assuming you don't have OC - which you won't on an 04) while using valvoline results in essentially no oil burned between oil changes.
Can anyone link that thread?
It's been shown that synthetics are superior to dyno oils on many fronts; however, most real car experts will tell you that the oil has less to do with wear than how your drive (slow vs. fast vs. throttle it at every opportunity), how often you change it (at the right intervals based on your driving habits and oil analysis), the cleanliness of your air filter, number of cold starts, etc., etc. Cold starts are a key factor, but is often an ignored aspect of engine wear.
Too many variables, but -- I'd go synthetic such as Penn Platinum, Mobil 1, Amsoil, German Castrol or Castrol Edge, or any other group III and IV oils.
Your best bet is to read the following: http://www.bobistheoilguy.com/
http://www.performanceoilnews.com/oi...nst_oils.shtml
m1 0w40 ranges from 7 to 20 hp better against all comers. I never thought oil could have that impact but I definately became a believer after switching to it
There is also perfomance. Look at the hp results on the following test:
BTW- I do use Mobil1- it meets my needs. I also may have more experience than 90% of those on the forum with 3 Volvos that have >1.2million miles jointly-- I wonder if the G's will reach >300K for most of us.
I think the 0W oils would also be more effective on cold starts. It will flow better than a 5 or 10w oil in the critical first few seconds while pressure builds.
I'm not kidding about the hp gains. I had my engine replaced under the OC tsb and ran dino 10w30 for the first 3500. Switched then to the 0W40 and the effect was instant and definately noticable. Revs come up quicker and the car just wants to run.
Honest to God just switching oils had more effect on the ***-o-meter than the $1500 I spent on a fast intentions exhaust
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
