Experienced some weird slippage
Old May 4, 2009 | 06:42 PM
ClutchBurner04's Avatar
So the other day, I was going down the hill in 3rd gear and right around 3000 rpm I felt a quick but slight tug and the "slip" light goes on about twice. This happened as I was turning slightly right going down the windy hill if that makes any difference...
I find this weird since my clutch is new and it's oem too. Not sure if I should be concerned but has anybody experienced this before? Thanks
Old May 4, 2009 | 06:52 PM
PAIXAO's Avatar
LOL at your SN and thread title...
I digress, could have been the road conditions
Old May 4, 2009 | 09:42 PM
lol yeasss, I sometimes rev around 1000-2000rpm and the let the clutch out slowly when I want a smoother take off. Meh...I'll stop that one day
Old May 5, 2009 | 05:48 PM
smr514's Avatar
that happens to me too whenever the road is a lil bumpy and i try to accelerate *slip light flashes.
Old May 5, 2009 | 08:51 PM
Should we be concerned about the mechanism behind this issue? Or maybe all Gs do this, and it is perfectly normal yeaah
Old May 5, 2009 | 11:07 PM
AARONHL's Avatar
Are your tires bald?
Old May 6, 2009 | 12:40 PM
smr514's Avatar
when i said bumpy roads i meant real bumpy, uneven, pot holes and etc... so i think the car is telling me not to hit the gas so hard. lol
Old May 6, 2009 | 01:18 PM
djamps's Avatar
Your VDC is tripping out. This happened to me when I got new rear tires and left the worn fronts on. It will also happen when you don't get the correct tire sizes or rim sizes. The diameter between front/rear ended up a bit off and the computer was tripping around some corners. When I put new front tires on the issue went away.
In the meantime, you can turn off VDC if its really bugging you.
Old May 7, 2009 | 03:28 AM
My tires are in okay condition I suppose, but given the input you guys gave me, I believe it's because the pressure in my tires and yes, VDC. I did gas going down hill...dunno why, just felt like it ya know? I have the (!) on, so I'll get to that when I fill up. Thanks
Freeman186
Sep 6, 2023 10:07 AM
G35-R
Nov 7, 2015 01:21 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
vamarris
Sep 26, 2015 12:56 PM
