Best spark plug for N/A mods?
Jul 13, 2004 | 10:53 AM
Should plugs be changed to get the best out of N/A mods?
What brand, type and temperature are suggested?
How often should they be replaced?
Reply 0
Jul 13, 2004 | 11:19 AM
Re: Best spark plug for N/A mods?
Because of coil on plug ignition, little can be gained and lots lost from changing plugs that oem had designed for engine.
You won't find a plug that will give you one more HP or the factory would have used it!
Every HP counts in Marketing a car real or imaginary!
Finding 4.0 cheap HP could get an engineer a big raise and promotion plus Geisha house entertainment for a week.
Watch out for DEADLY multi electrode plugs which have been know to promote detonation and have individual electrodes knocked off and score the cylinder liner after stress........+4 brand.
Iridium is usually a costly substitute for platnium.
If you stay with oem and change at 60k [vs alluded to 100k life] you will be way ahead!
Reply 0
Jul 13, 2004 | 12:22 PM
Q45tech,
I just paid $5.99 for 8 Platinum Spark Plugs for the Sequoia. They had 4 points on the ends and were supposed to have a 3 year money back guarantee. Are these the "+4 brand" that you're referring to? If so, I can take them off and get a refund.
I thought I was doing a GOOD thing by buying them. [img]/w3timages/icons/crazy.gif[/img]
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Reply 0
Jul 13, 2004 | 05:51 PM
I agree with Q45 tech, unless you are putting out insane amounts of hp (requires colder plugs), the stock plugs should be fine. What do they say - 1 step colder for every extra 100hp?
Copper plugs might give you a few hp, but they'll have to be changed very often...not worth it IMO
Reply 0
Jul 13, 2004 | 06:14 PM
neffster...et all,
i have always thought that the +4 plugs were a gimmick anyways.
the reason is because at a microscopic level, one of those legs is longer than the other 3, and electricity will always take the path of least resistance. it looks cool, but i think it will act and perform like a regular plug.
Chad
Reply 0
