help with do-it yourself transmission rebuild or just go with dealer
Old Jun 9, 2009 | 03:28 PM
pcr1989's Avatar
my 2004 g35 coupe with 6mt needs a new tranny.dealer quoted 3,000 for parts and labor for new tran and new clutch.stock oem parts.
1.i already have done the research and this seems like a good price but if i am having them pull out the tran i might as well get a racing clutch and lighter flywheel and have it installed as well.anyone have experience with dealerships on installing aftermarket parts?
2.found a transmission rebuild kit with snychros for 740.would it save a good amount of money to just try and do it myself(and is there any special things i need to know about taking off the tran and replacing it) or should i just save time and the hassle and take it to the dealer.
thank you for any input
and also i was thinking of going with like a act stage 2 and fidanza flywheel but would a nismo clutch and flywheel be comparable?
Old Jul 24, 2009 | 06:53 AM
Lmoye's Avatar
Where did you find the rebuild kit??
Old Jul 24, 2009 | 05:40 PM
Tollboothwilley's Avatar
nismo clutch and flywheel are both made by Exedy, same as the stock. NISMO is only slightly lighter than the stock(flywheel) but the clutch is much better.
I would stick with the ACT and FIDANZA like you are thinking. I think you will like the combo better. Just know that with the fidanza flywheel that you will get chatter.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
f22raptor
Mar 18, 2016 08:50 AM
Gabe83714
Oct 6, 2015 06:40 AM
