Some mods I am looking at.. help
Old Jul 21, 2004 | 10:57 AM
bolinp78's Avatar
Hi, currently I am looking @ gettingn for my 5AT diamond graphite G -
Crawford v5 Plenum
Z-tube
K&N filter
Clear Corners
Aluminum Pedals
OEM Front Lip
I also hear that Helix test pipes are a good cheap addon for about 170$. Does anyone have any experience with them?
This will all run me about 1050$ and that includes shipping / tax but not install. If my upper limit is about 1200$ do you guys think I could be doing anything different that would be better?
Old Jul 21, 2004 | 01:58 PM
neffster's Avatar
Re: Some mods I am looking at.. help
Looks good to me. The only thing you might want to have help installing is the straight pipes.
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Jul 21, 2004 | 07:33 PM
Instig8rG's Avatar
Another mod that is cheap and easy would be one of the Grounding Wire kits.
Old Jul 21, 2004 | 07:37 PM
zazaracing's Avatar
Team Transport Member
IF you do all those free flowing mods You most likely will lose HP due tot he fact that your ECU is not set up to run.
That is my opinion and I know a few people that will back me up on that.
(you can have test pipes made for much cheaper at a local muffler shop dont waste you money on the helix!) again my opinion
03 6MT Coupe Blk/Blk&gt; Injen CAI, Hotchkis adj Sway Bars, Test Pipes&lt; "Nt G R8D" Aj
Old Jul 21, 2004 | 11:59 PM
adxcpa's Avatar
Helix will not be CARB approved so you may have problems having your G35 smog. Another good mod would be the U/O pulleys (approximately $300). Good mod hunting.
ADX
Old Jul 22, 2004 | 03:55 AM
glennp_1999's Avatar
dump the front lip and just get a decent spring setup or maybe an exhaust to compliment all the intake mods you're doing.
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Jul 22, 2004 | 09:33 AM
bolinp78's Avatar
ok.. I have decided not to do the plenum.. I am now set on going with
Ztube
K&N filter
Aluminum Pedals
Clear Corners
OEM Front Lip
Hotchkis Sway bars (? maybe ?)
With JUST the sway bars will i notice a handling difference or would i need a whole kit?
Also, after I had my car for 1200 miles i got the ECU reset and have been driving it hard ever since.. what did you mean by the ECU comment?
Old Jul 22, 2004 | 11:07 AM
Airs414's Avatar
Your car would be running to lean, you would need the technosquare ECU upgrade.
Jump and the net will appear
Old Jul 22, 2004 | 11:14 AM
bolinp78's Avatar
are u freaking kidding me? no way.. why would i need the TS upgrade w/ just a ztube and a k&n filter?? that makes no sense
Old Jul 22, 2004 | 04:00 PM
Airs414's Avatar
if you replace the plenum and high flow cats you would need to.
Old Jul 22, 2004 | 04:34 PM
G35_TX's Avatar
Not neccessarily. I am working on a idea that migth not require the TS ecu upgrade for those mods. We just need to find a way to get in a little more fuel.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, K&N Drop In
Track: 14.32 at 98.79 mph 2.2032 60ft
Dyno 07-07-04 - 234.2 hp & 233.8 tq
http://www.g35world.com
Old Jul 22, 2004 | 05:04 PM
bolinp78's Avatar
well as i stated before the only performance mods i am looking at as of now are the Ztube, K&N filter, and Hotchkis sways.. i dont think ill need an ECU upgrade just for those..
Old Jul 22, 2004 | 05:12 PM
Catatafish's Avatar
My opinion is that the ECU is already prepared for the variance of air that the NA mods described will do to it. Sure the TS reflash will help, but not necessarily required. Don't be afraid to do all those mods without it, you will be fine.
Many of the "lean" problems cited on this board have been reported from dynos that simply aren't qualified to report the real lean/rich condition, as Q45Tech has eloquently explained far better than I could. Click his username and read the details for yourself if you'd like to understand why, I'd just botch his words; but he's convinced me with mathematics.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
