z tube help
Old Jul 10, 2009 | 03:19 PM
OCG35's Avatar
a small piece of split rubber hose over the AC line takes care of any potential rubbing issues... many times the position of the MAF housing will determine clearance - for me with the sensor straight up there's no rubbing... to the driver-side fender there is slight rubbing and straight down the plug touches firm - this is all with Stillen air box - recently I installed OEM air box (first time in over 4 yrs) and it doesn’t rub at all in any position.
Anyway - I keep a piece of split rubber tubing on the line as precaution.
Old Jul 10, 2009 | 03:47 PM
junbug's Avatar
Originally Posted by DiGil
I really only had a problem with the A/C line when I had a Popcharger on the z tube. With the stock Rev-Up airbox there is enough clearance. Guess you should make sure in any case, though.
Good point. I have the Stillen intake and no clearance problems. Been on it for 4 years 75K miles no issues. But all these folks on the board make me nervous with their scary stories, so after four years of no issues, I finally put a hose and lubed it just for good measure.
Old Jul 11, 2009 | 08:29 AM
SoxUcf's Avatar
Does it matter what year Z you pull the Z tube from to put on a particular year G? I can't think of a reason why it would matter but I thought I would check before I pick one up online from someone.
Old Jul 12, 2009 | 09:32 PM
OCG35's Avatar
as long as its from a DE (single intake/tb) it will work
Old Jul 25, 2009 | 01:37 AM
djekua's Avatar
The sound must be that different
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
