Radiator cap stress?
Old Aug 7, 2009 | 11:51 AM
cliffords's Avatar
I may be wrong but I believe the OEM radiator cap has a 1.0kg (about 16lb?) Doesn't the "popular" replacement caps of 1.3kg (16.8lb) put an unwanted stress on the cooling system?
CliffordS
Old Aug 8, 2009 | 05:16 PM
Tollboothwilley's Avatar
Stock radiator cap is .9 bar which is about 13 PSI.
I'm currently running a 1.2 bar cap (from the 1990 300ZX) which is about 16 PSI.
It will put a little more stress so if you have weak coolant lines you are more likely to break one. Its not that much more stress. It will raise the boiling point of the coolant some.
Old Aug 8, 2009 | 06:06 PM
cliffords's Avatar
Thanks for the correct information. I'll go with the 1.2 bar cap.
CliffordS
Old Aug 13, 2009 | 03:32 PM
ttrank's Avatar
Grocery getter
Have been running one for years with no issues.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
BradMD_96
Oct 6, 2015 09:31 AM
vamarris
Sep 26, 2015 12:56 PM
