WireTuck in Progress and Painted Valve Covers!!!
Old Aug 13, 2009 | 01:26 AM
bikinilust's Avatar
thanks guys. Good to hear from you Sean and Dave
Old Aug 13, 2009 | 01:36 AM
CandlestickPark's Avatar
ill Sedan
Nice work dude!
Old Aug 13, 2009 | 01:41 AM
O HELLA JDM's Avatar
cool cool
Old Sep 13, 2009 | 03:08 PM
bikinilust's Avatar
bump
Old Sep 13, 2009 | 11:03 PM
2drwild's Avatar
Great work.Mike you ever going to finish your car?
Old Sep 13, 2009 | 11:39 PM
Extreme G's Avatar
Is there any DIY for Wiretuck?
Old Sep 16, 2009 | 09:47 PM
bikinilust's Avatar
Found some pix that i took during the side wire harnesses tuck
Old Sep 16, 2009 | 09:52 PM
bikinilust's Avatar
Everything removed so i can tuck the side harnesses.
Removed front bumper, grill, front wheels, wheel well liners, battery covers, under engine plastic shroud, Windshield wiper funnel, Coolant overflow, hood sensor bracket, etc...
Old Sep 16, 2009 | 09:56 PM
bikinilust's Avatar
Disconnected everything from the side wire harnesses. Labeling both ends of the connects so nothing gets mixed up.
Wicked_limitz's Avatar
looking good man.
Old Sep 16, 2009 | 10:09 PM
bikinilust's Avatar
Routed disconnected side wire harnesses through side hole hidden in Battery compartment and in Brake compartment. In battery compartment, hole is hidden behind the "3 wire harness plug holder". Its more than big enough for the wire harness to go through. In the brake compartment, its in the exact same location, just in reverse. Note: for brake compartment, wire harness has to be fished through with a coat hanger and electrical tape because the ABS metal block is in the way to do by hand.
Old Sep 16, 2009 | 10:11 PM
bikinilust's Avatar
sorry dont have any other pix from the install
Old Sep 16, 2009 | 10:20 PM
bikinilust's Avatar
once the wheel well liners were put back, the wheel wells look completely OEM. Everything is covered by the wheel well liner. Also, the battery and the brake compartments look oem as well. Unless you are putting your nose in there and know what you are looking for, one cannot tell that there are wires that are being tucked. Everything looks like its the way it should look from factory.
Old Sep 16, 2009 | 11:08 PM
F5TG35's Avatar
wow looks great!!! :biggthumpu pbiggthumpup:
Old Nov 22, 2009 | 08:49 PM
  #30
jt money's Avatar
how did u relocate your spark-pplug harness?
