Engine cover panting?
Old Aug 7, 2004 | 02:06 AM
duckygirl's Avatar
Okay if I wanted to paint my engine cover how would I go about doint it? What kind of paint should I be using and what would I need to paint it?
Old Aug 7, 2004 | 09:49 PM
afr0puff's Avatar
Supa Dupa Moderator
Re: Engine cover panting?
Use a high temperature paint... It also needs to stick to flexible plastic. You may need to primer it, but some people just use the high temp paint.
http://www.anythingbox.net
Old Aug 8, 2004 | 02:48 AM
Triji's Avatar
I used Dupli color paint from Autozone. I did 2 coats of primer on the area I was painting and taped off the outer area w/ masking tape. After the primer dried totally I used 3 coats of paint being very careful to keep my distance so not to get any runs in the paint. I removed the emblem by using a hair dryer and peeling it very slowly before I painted. After the paint was set up to my satisfaction I put 3 coats of clear coat on let dry and re-installled.
Good Luck with your project.
2004 Coupe, 5AT, Twilight blue / Willow int, K&N Typhoon CAI, Hyper Grounding Kit, Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium, Val 1.
Old Aug 8, 2004 | 02:49 AM
Triji's Avatar
Old Aug 8, 2004 | 02:50 AM
Triji's Avatar
Old Aug 8, 2004 | 06:17 PM
duckygirl's Avatar
Cool I hope that nice orange or pink color I like.
Old Aug 9, 2004 | 12:44 AM
SI_G35Coupe's Avatar
I was going to contact ZPresence from the forums over on 350zfrenzy.com... he works in an automotive paint shop and owns a 350z... he's made a good side job out of doing the engine covers for Z drivers.... his work is pricey but top notch....
he'll do any factory color or custom mix that you'd like... check out this huge thread about his work...
ZPresence's Painted 350z Engine Covers
i attached one of the pics of his custom work above... also PS i don't work for him or anything i just think his work is awesome
Old Aug 9, 2004 | 11:03 AM
afr0puff's Avatar
Supa Dupa Moderator
<hr></blockquote>
Orange and pink? LOL! If you like it, go for it. Post pics though. Interested to see how it turns out.
Old Aug 10, 2004 | 03:46 AM
duckygirl's Avatar
I want to really do something like this setup here.
Old Aug 10, 2004 | 09:23 AM
afr0puff's Avatar
Supa Dupa Moderator
Interesting... but what color is your G? Will your color scheme look good? Do you just want to do the engine cover or do you also want to do the battery cover?
Just find a place that has Dupli-Color Engine enamel and high heat paint. They have limited colors though:
[url]http://www.duplicolor.com/products/engine.html[\url]
If you don't like their colors, then you will have to get something custom made from paintscratch.com. Just give them a paint code for the color you want, and order a can of clearcoat from them with "FLEX" added in. Don't forget the primer for optimum results.
Old Aug 11, 2004 | 01:12 AM
smokinG's Avatar
Doesn't that yellow dipstick and stickers drive you crazy. Man I couldn't take it, I sprayed the dipstick and scraped those stickers off and I felt much better.
2003 Blk/Blk Premium w/navigation
Tinted Windows (20%)
Chrome Wheels
BRM Catback Exhaust
Injen CAI (blue)
Unorthodox Crank Pulley (blue)
Clear Corners
Grounding Wires (blue)
255/45ZR17's rear
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
