I'm installing a Zex nitrous adapter onto the fuel pressure?
What is the best (easiest) way to relieve fuel pressure prior to doing this?
Thanks
Thanks
http://www.cj-motorsports.com/342install.htm
Part 2
I had to do that to bring my fuel pressure down
but I also have a fuel pressure regulator to make adjustment
Part 2
Thanks.
I just got a copy of the G35 service manual as well and it says to simply remove the fuel pump fuse located in the IPDM E/R (fusebox by battery), and then just start the engine and run until it stalls. Then crank a few more times to release all fuel pressure.
^^^ that, and also unscrew the gas cap.Originally Posted by liche
Thanks.I just got a copy of the G35 service manual as well and it says to simply remove the fuel pump fuse located in the IPDM E/R (fusebox by battery), and then just start the engine and run until it stalls. Then crank a few more times to release all fuel pressure.
my bad I thought you were asking about relieving pressure on the long run not just one time thing.
I had my gas tank exposed so I just disconnected the harness going to the pump
