2 Nissan Data Scan II users
Old Sep 30, 2009 | 12:52 AM
Alex_81's Avatar
Is there anyone who owns the Blazt-II cable (aka "BlaZt OBD-II cable")? The one which intended to be used with NDS-II.
Can you please try to dump your cable firmware using the attached tool? Just need to check one thing... Unfortunately for me, I do not have a direct access to the cable currently. There is no need to plug the cable into the car's OBD-II socket, merely connecting it to the PC should be enough.
The istructions are as follows:
1. Make sure you have appropriate cable drivers installed.
2. Find out to which virtual COM port number the cable is connected (for ex. you can check this in the NDS settings window).
3. Then, from within a command-line prompt, type:
fwread COMx
where x is a COM port number to which your Blazt-II cable is attached, ex. fwread COM2
A file "fwdump.bin" will be created if the reading was ok, otherwise some error message should be displayed. In the last case, please provide a copy-paste of the error output.
You can either attach the resulting firmware file here or send it directly to me via email: lavos0@gmail.com -- ex. in the case if the resulting file will be a bit large for attaching. Though it is very unlikely - I expect something less than 30K.
File Type: zip
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Danielek
Sep 10, 2015 06:18 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
