Oil Pressure Light
Old Oct 6, 2009 | 08:53 PM
bp240's Avatar
Oil Pressure Light
okay so recently when I've been taking turns fast my oil pressure light has been lighting up. when i complete the turn, the light turns off again. still, its weird that this is happening when its never happened before. anyone know why this is happening or had this happen to them?
Old Oct 7, 2009 | 07:56 AM
Q45tech's Avatar
Be sure to put an accurate gauge on engine as the light means less than 3 psi unless the sensor wire is intermitent.
Oil starvation on takes seconds to do it's destructive work.
Old Oct 7, 2009 | 04:36 PM
Canadian's Avatar
Canada, eh?
I'd take it somewhere asap to get it checked out. With that light on it could spell disaster.
Old Oct 8, 2009 | 09:33 AM
djamps's Avatar
My guess - it means you don't check your oil and it's so low it already damaged your engine. When the light comes on, the damage is already done.
Good luck and be sure to take better care of your engine.
Old Oct 8, 2009 | 09:53 AM
GreenGoblin's Avatar
The goblin resurrection
^ yup that is what I was thinking, he probally has and OC motor and does not check the oil level, and when taking the turns he is tripping the sensor...
Old Oct 8, 2009 | 10:40 AM
velomack's Avatar
You still under Warranty? You may need it.
Old Oct 8, 2009 | 03:55 PM
bp240's Avatar
nah im not under warranty anymore, i have like 55k miles. thing is though i just changed my oil (synthetic) around 4k miles ago and ive checked my oil 5 times in the past few days to see if its my oil level but it all looks good. i know what the light is there for, and if it was on all the time i wouldnt be driving it, but the thing is that it only comes on around hard curves.
Old Oct 8, 2009 | 04:02 PM
bythabay's Avatar
To start, I would take a look at the oil pressure sensor and make sure it isn't leaking and/or damaged. Make sure the wires are all in good shape. Maybe try moving the wires around a little while the engine is idling, and see if the light flashes. If all is ok, remove the oil pressure sensor and in its place screw in a pressure gauge. You can buy one through any good auto parts store. They come with all different kinds of adapters so you can screw it in. Then follow the FSM procedure for testing oil pressure. There is a reading you must check at idle, and another reading you must check at 2100 rpm (that's if my memory serves me correct). It's very easy to do and I would highly recommend checking especially if you are out of warranty..
Old Oct 8, 2009 | 06:54 PM
djamps's Avatar
The only way I can see, both by logic and experience, the pressure dropping when turning is if the oil is low. Add a half quart and see if it goes away.
Old Feb 20, 2021 | 10:13 PM
Brad6080's Avatar
base 04 sedan and 07 sport sedan
I know this is an old post, but I'm trying to find out if the oil light is supposed to come on when I turn on the ignition or not. At the moment it's not. Just bought the car with a seized engine and replaced it, but not seeing the oil light at all. Not even sure where it is exactly since I've never seen it light up
Old Feb 21, 2021 | 12:39 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes, with the engine not running turn the key to the ON position and the dash will do a lamp test. This is the same on almost every single vehicle but some of the newer cars that have full LCD screens don't actually have idiot lights so those are pretty much the only exception.
Here is a snippet of a G35 dash and I pointed to the low oil pressure indicator.
Old Feb 21, 2021 | 01:13 PM
Brad6080's Avatar
That's what i thought too. Mine is a 07 sedan with the keyless ignition and the gauge cluster is different, but I'm sure it is supposed to have one. Not seeing it though
Old Feb 21, 2021 | 01:26 PM
cleric670's Avatar
BANNED!!!
Ok I didn't know which platform so I posted a pic of a DE motor. Here's what your HR motor should look like for a split second right after you push the ignition button.
Old Feb 21, 2021 | 01:32 PM
Brad6080's Avatar
This is a cluster like mine, but the light isn't coming on during the ignition on engine off check
Old Feb 21, 2021 | 01:42 PM
cleric670's Avatar
BANNED!!!
You might have a bad instrument cluster, or someone may have intentionally damaged the board because an oil light on the HR engine usually means the galley gaskets are leaking which is a somewhat common and very expensive repair. The previous seller may have been trying to hide the galley gasket problem by just breaking the oil pressure light.
​​​​​​@treacherous might chime in about how his oil pressure light works, I think he has a V36 sedan as well.
