Stillen HF air box spec?
Old Aug 11, 2004 | 05:02 PM
doorbell7942's Avatar
Any one know the spec on Stillen high flow air box intake filter? For example, the front and rear radius and the length. I'm trying to make homemade version of this intake with oem air box. I think with little mod to oem air box and filter that fit would work... $200 for this Stillen's intake is way overpriced IMO...
Haven't taken out my pop-charger filter but just from eyeballing I think it is too big to fit inside the oem air box...
04c, Black, AT, PIAA, AL padel, smoked clear corner, 6th grounded-wire, z-tube/pop-charger, UR pully, Data grille & Gialla spoiler, 15% tint
Old Aug 11, 2004 | 06:07 PM
wren57's Avatar
Re: Stillen HF air box spec?
Why not just get a k&n dropin filter for the stock airbox and work from there?
03 350z
Old Aug 11, 2004 | 06:59 PM
JWT pop-charger has more aggressive sound than K&N filter. I want best of both world... aggressive sound with cooler intake temperature. I don't think heat shield works that well on pop-charger...
Old Aug 11, 2004 | 09:48 PM
Hydrazine's Avatar
Doorknob, ;-)
You don't need to make an exact copy of the Stillen radius. The inlet radius on the stock box is so small that any increased radius that you put on would increase the inlet discharge coefficent very rapidly. The Stillen radius is already so large that making it any larger won't make a functional difference.
A radius half that of the Stillen would be more than adequate.
In Theory, practice and theory are the same.
In Practice, practice and theory are not the same.
2004 G35 6MT Blk/Blk Sedan Stillen Air, Stillen Exhaust
Old Aug 12, 2004 | 01:29 AM
I just want to know what size intake fitler (length, width, and height) i need to fit inside oem air box. I figure stillen high flow air intake would be good place to start. I'm not trying to copy, just need some spec to start working on my idea...
if you have Stillen air box would someone measure the spec of the intake filter... thanks in advance
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
Team STILLEN
Aug 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
