1/4 times
Old Oct 24, 2002 | 09:41 AM
TurbotrixRacing's Avatar
1/4 times
Has anyone made it to the drag strip yet? I managed a 14.5 @ 97 with a traction limited 60' time last night. I made both runs with the traction control off and one in manual shift mode. Both times were about the same.
Stock tire pressure, 92 oct. fuel and 3597 lbs with driver.
I should have dyno numbers next week and hopefully a few performance upgrades in the near future.
-Jeff
Old Oct 25, 2002 | 07:21 AM
Re: 1/4 times
The car is an auto sedan. On the first pass I left it in drive, VDC off, and launched at around 2700rpm and the tranny shifted at about 6600. The next pass I heated the tires and tried to shift it manually. I had the same 2.2 60' time but picked up 1 mph at the end. My goal was to shift at 7000 but the tranny has a long delay and I hit the limiter going into second. I'll give it a try again next week and see if I can perfect a technique.
I'm use to racing a 9 second/ 150mph Eagle Talon so it's difficult to race something so different on the first night.
Jeff
Old Oct 25, 2002 | 01:57 PM
G35Lin's Avatar
Multi-Spoked Mod
Re: 1/4 times
Wow, fast car! What mods did you put in ur talon?
What rpm is the limiter set at? You can go towards 6600rpm wihtout hitting the limiter? Thats surprising
Did you make any mods? CPU changes?
Old Oct 25, 2002 | 07:24 PM
envykillz's Avatar
Re: 1/4 times
step on the brake hard enough so that the wheels dont spin.
and do it right before you are about to launch. not two seconds, but right before.
the rev limiter on my car seems to be 6900-7000
Old Oct 26, 2002 | 03:31 AM
Bukwheat's Avatar
Re: 1/4 times
Damn....14.5 is pretty good for an automatic!!!
Old Oct 26, 2002 | 11:25 AM
envykillz's Avatar
Re: 1/4 times
i want 13's but all motor
Old Oct 28, 2002 | 07:17 AM
Re: 1/4 times
Tom,
The race track has a much stickier surface than the street. I have tried the same launch around town and it just spins.
I broke the Talon on the dynojet Friday (at 602 lb/ft. torque) so I may take the G to the track this weekend for the "Import vs. Domestic" bracket race.
Muski_G
Dec 1, 2023 11:11 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
MR M37s
Oct 30, 2015 08:32 AM
