Ignition msd-hks???
Old Nov 8, 2009 | 11:04 AM
REDG35DRIVER's Avatar
Ignition msd-hks???
Im intrested in getting an ignition system but i dont know how to go about this. What brand should i be looking into will msd work and what modles should i be looking into has anyone installed an ignition system and was it worth even doing.
Old Nov 8, 2009 | 06:44 PM
Tollboothwilley's Avatar
why are you looking into this?
Old Nov 8, 2009 | 07:17 PM
SDGenius's Avatar
I have the HKS DLI-II and i'm happy w/it
Old Nov 9, 2009 | 12:22 AM
what benefit are you getting out of the ignition boost?
Old Nov 9, 2009 | 12:40 AM
SDGenius's Avatar
Stock ur spark automatically starts dyin' out at high speed & RPMs, Nissan did this as a fail safe, like the rev limiter. w/an ignition amp, you have optimal spark throughout the power band. when i was at Technosquare, i had my rev limit raised to 71k too. the car just keeps pulling, hard, well passed 100mph.
Old Nov 9, 2009 | 12:43 AM
pfarmer's Avatar
Should be well pass 1000 mph for urrrr currr.
I would like to see the voltage output of the stock packs as far as dying out.
Old Nov 12, 2009 | 07:44 PM
InShAllAh's Avatar
I guess I'll give you some valuable information. The only real need to use anything like that is if you plan on running some serious boost (15+ PSI). The coil over plug system that comes W/ the Z's and G's are fairly strong. If you do decide to blow some money on an ignition system, based on my personal experience I would go MSD. The HKS system is an easy install but I have had a problem with the HKS system on my boosted Z. I actually fell that the HKS system directly contributed to my second motor being blown.
Old Nov 12, 2009 | 09:52 PM
I guess on the stock ECU the ignition might die. My ignition is run through my Greddy Emanage so the ECU no longer controls that when I hammer down on the throttle.
Old Nov 12, 2009 | 11:55 PM
Sylvan lake V35's Avatar
Here is an interesting perspective. XKR (not sure if you guys know him over here but browse the FI section) gave me his HKS DLI II (he threw it in with some stuff I bought) because with some dyno testing Forged Performance did on his last build i think it was 800whp at 22psi. It made no noticeable difference so our ignition systems are very capable as is and you could spend your $300-500 better places.
junon
Jan 14, 2023 09:37 PM
mike730
Jan 12, 2018 04:25 PM
mtlruss
Dec 20, 2015 01:51 PM
pasjr1972
Sep 1, 2015 10:17 PM
.cakestar
Aug 4, 2015 09:05 PM
