Time to change fluids!
Hey, I tried to search but I just wanted all of the info in one place if at all possible...
What are the best fluids to use for each of the following...but also, if not needed, the cheaper one would work too....Also, I am just going to order all of them online and try to do what I can by myself and for the rest, just take it to the local mechanic but I will just give him the fluids so about how much of each will I need. Thank you
Transmission:
Power Steering:
Rear Differential:
Brake:
Anything else I left out?
Also, I bought this car with 47,000 miles on it and now have 50k? Assuming that the service was not done accordingly, is there anything else you recommend doing around this mileage? Thanks for all the help.
Transmission:
Power Steering:
Rear Differential:
Brake:
For the transmission, use the recommended Nissan matic J for auto transmission, or amsoil for the 6mt (I think it's 75w90 )
For power steering I would do castrol or amsoil.
As for brake fluid, either mobil 1 or castrol
Rear diff , I went to the dealership ans they gave me pennzoil 75w90( same as the 6mt fluid/oil.
And as for coolant, prestone. Hey it's better than the advance auto brand!
