Black smoke from mufflers when punching it....
Old Dec 7, 2009 | 06:14 PM
bikinilust's Avatar
My friends are telling me that i get a big burst of black smoke when i punch it. And when i say punch it, Im already rolling at a moderate speed, then floor it. Or i down shift n floor it.
Any ideas as to what it is?
FYI: Apexi air filter, One piece stainless steel intake tube [kinda like Fujita], 1/2" plenum spacer, new NGK Iridium spark plugs, New valve covers, UR pulleys, Strup Ceramic coated headers, fresh engine + tranny + diffy fluids, coolant delete mod....stock exhaust n stock cats at the moment.
Oh and speradically i get a random misfire code. Maybe like once a month or two months.
Old Dec 7, 2009 | 08:44 PM
liche's Avatar
Black smoke is usually indicative of your engine running excessively rich.
If you are running NA, you may need a tune to help lean your mixture a bit, or if your running FI, it could be normal.
Old Dec 8, 2009 | 02:48 AM
bikinilust's Avatar
hmmm... looks like ima have to hit up a master mechanic on a side job :-(
Old Dec 10, 2009 | 07:12 PM
03threefiftyz's Avatar
Try cleaning the maf sensor.....it's easy and cause these symptoms. It can also be the pcv valve....usually there will be a hint of blue in the smoke because this will cause some oil vapor to bypass into the plenum. The pcv is a common issue on VQ's.
Old Dec 10, 2009 | 10:48 PM
bikinilust's Avatar
how can one test the PCV?
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
avalino
Aug 6, 2015 01:42 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
hippiGlass
Engine - Exhaust
Jul 16, 2015 07:48 PM
