OBD-II Sensor Location
Old Jan 4, 2010 | 01:35 PM
b4cheung's Avatar
So I already did a quick search on G35 driver for this, but I couldn't find the answer.
I don't know where to plug in the OBD2 scanner to pull a code. This morning, I backed out of the driveway, and the check engine light went on, and the transmission wouldn't shift out of first. I did an ECU reset to see if that would help and everything works normally again. I have an OBD2 sensor, and I wanted to pull the code to see what happened.
It's a 2003 G35 Coupe Auto.
On 6mt, it says, "connect a suitable Scan Tool to the DLC, located under or on lower portion of instrument panel." Is the instrument panel referring to the dashboard? I checked under the steering wheel, but all I saw was the lever that allows me to move the steering wheel up and down. Could anyone give more detailed instructions or a picture of where to find it?
Thank you.
Old Jan 4, 2010 | 01:40 PM
Jeff92se's Avatar
Red Card Crew
It's under the dash. Driver's side. Just left of the steering wheel.
Old Jan 4, 2010 | 02:58 PM
thechiguy's Avatar
Muski_G
Dec 1, 2023 11:11 AM
ZoominG35
Dec 6, 2015 03:11 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
