P2135 trouble code service engine soon
Old Jan 5, 2010 | 11:41 PM
05skyline's Avatar
About a week ago my car would not accelerate and 3 lights (service engine soon, slip, and vdc) came on all at same time. I turned engine off then back on and the car has drove normally since but the service engine soon light was still on. After about 6 days since this occured, the service engine soon light disappeared on its own. I took my G to autozone and they read it as P2135 code which had to do with the throttle position sensor error. My G has about 58K and is an 05 coupe. Should I get this fixed at dealer or since light went away then is problem now fixed? Has anyone else had similar problem and how did you go about fixing it. Any suggestions? Thanks.
Old Jan 6, 2010 | 12:02 AM
JOKER's Avatar
CLUB MODERATOR
New throttle body will fix this problem.
clear the code. If it comes back then you need a new TB.
also a gas pedal switch (or what ever it's called) could also cause this code to show up.
Old Jan 6, 2010 | 10:05 PM
superchargedg's Avatar
The light will come back on and im on my 3rd tb in 77,000 miles.
Old Jan 6, 2010 | 10:30 PM
Tollboothwilley's Avatar
3rd TB huh? Wow, that sux. I'm at 150K miles and only on my 2nd because of me cleaning it.
Old Jan 7, 2010 | 09:39 PM
05skyline's Avatar
How do you clear the code? will Clearing code fix the problem so I won't have to get new TB?
Old Jan 9, 2010 | 11:58 AM
gck's Avatar
gck
get a new throttle body!... you can find some in the marketplace.(dont try to clean it and put it back on...) just get a new one!
Old Jan 9, 2010 | 03:42 PM
05skyline's Avatar
Also, is there a way to tell if its the gas pedal switch or the TB causing the code? Where is that gas pedal switch located? Thanks.
Old Jan 9, 2010 | 03:43 PM
05skyline's Avatar
How would I tell if I need a rev-up or non-rev TB?
Old Jan 9, 2010 | 11:50 PM
the Tb's are all the same from 03-06
Old Feb 1, 2010 | 10:19 PM
05skyline's Avatar
ok thanks
Old Feb 8, 2010 | 11:43 PM
05skyline's Avatar
ok, so I havent changed the throttle body yet and my car recently stalled again this week. Would a good throttle body around 50K miles be ideal to buy to swap it out with mine now or should I just buy a brand new one? Just wanted to see if a good used one would work to save some money. Thanks for input...
Old Feb 9, 2010 | 07:19 PM
Infiniti has the remanufactured ones in stock as i got mine for $149 with the gasket but thats been at least 2 years ago.
Old Feb 9, 2010 | 11:23 PM
05skyline's Avatar
O ok, so a good throttle body around 50K miles wouldnt be ideal to buy?
Old Feb 17, 2010 | 05:53 PM
hg35x's Avatar
I had the exact same symptoms and error code - mine was the electronic throttle control off of the accelerator - I believe it was part# 18002-am81d. I have heard more problems causing this code from the throttle body, but replacing this (by dealer) fixed mine. 2004 G35x - 11k miles.
Old Jul 1, 2013 | 10:31 AM
vonstallin's Avatar
Had the same problem and code.
Local dealer said $300 for reman....blah...
Auto Zone said $229 online (called the store and they said $350)
Parts Geek had it for $130 and I get $40 back when I return the core...so $90. cant beat that.
http://www.partsgeek.com/catalog/200...ttle_body.html
I was really debating on getting a Hitachi since its made by them for nissan. but went with the A1 Cardone
Question:
After the relearn, do I have to do something to remove the Service Engine Soon sign?
And do anyone have the relearn procedures listed here? thanks
Muski_G
Dec 1, 2023 11:11 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
newg37
Jul 26, 2015 09:32 AM
igking
Jul 19, 2015 01:12 AM
