Black Smoke from Exhaust under acceleration and Compression question
Old Jun 23, 2020 | 09:49 AM
Jodi Doe's Avatar
2005 g35 sedan
Originally Posted by James_V35
Ok have ruled out blown or leaky headgasket between 3 and 5. There is just nothing to suggest it could be this, just a coincidence they are next to each other. No coolant mixing with oil, no coolant or oil loss, never overheated, no white smoke from exhaust, runs smooth. Ruling out cracked or warped head too, no oil or coolant leaking from engine anywhere, engine externals completely clean and dry.
I'm thinking it's the rings. Not sure how hard it is to change the rings?
Regarding the smoke, looks like it is deposits being blown from the exhaust under high pressure and not fuel, not rich enough and doesn't smell like unburnt fuel at all. Could be clogged cats? I had a huge amount of carbon buildup which I had cleaned out a while back.
Haven't pulled the plugs out, had them replaced about 5000 ago because I had oil pooling, had it fixed up. Other than that I think the plugs were ok.
Were you able to solve your black smoke issue? I bought 2005 g35 that sat on the driveway for months. It failed smog cause of some mild black exhaust smoke at high rev during the snap test. I have replaced plugs and fuel pump/regulator, new air filter, cleaned out the mag sensor. I don't know what else to do. I'm guessing it's on rich side due to black smoke. I have used fuel treatment n driven the car to burn old gas and it still getting black smoke. Do I need to replace fuel injectors that could be leaking? I replaced new ignition tube seals due to oil leaks. I found some coil packs that were soak with oil but I cleaned it out with brake cleaners. Could the plugs be bad but not enough to trigger a check engine light? Car has no trouble codes currently. Please anyone with tips and suggestions would be appreciated. Thank you all.
MyfistYourFace
Aug 8, 2015 11:58 AM
avalino
Aug 6, 2015 01:42 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
BlackGee35
Jul 21, 2015 07:24 PM
