Ignition Coil Oil Leak??!!
Old Jan 24, 2010 | 05:59 PM
G35SittinDubbed's Avatar
Ok so heres the deal, I'm sure everyone is familiar with the infamous ticking noise that has been talked about on here. Well I was changing my spark plugs to see if that could have been the problem and upon pulling the ignition coil off of one of the plugs, I seen it had oil down around the plug. Another thing I noticed was that the sleeve part of the coil spun freely unlike the other 5 which were stiff. Could it be that the ignition coil has gone bad/lost its seal or a bad seal on the valve?
Old Jan 25, 2010 | 04:49 PM
Tollboothwilley's Avatar
if you have oil in your spark plug cylinder then your valve covers are leaking.
covered under powertrain warranty 6yr 70K miles. If you are covered call the dealer, if not, you should consider replacing the leaking valve cover(s).
ignition coils that are sitting in oil will have the rubber swell and it will ruin the coil.
nissandrifter32
Dec 22, 2015 04:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
UT G35
Sep 3, 2015 03:58 PM
