How do you remove the pilot bearing
Old Jan 26, 2010 | 09:07 PM
GMcAfee35's Avatar
Just like the title states...How do you remove the pilot bearing?
Old Jan 26, 2010 | 09:57 PM
superchargedg's Avatar
Pack the hole full of grease and find a suitable size solid peice of metal tube(solid) and give it a whack with a hammer.....it should pop out.At least that is the way i used to do it on older cars and it worked most of the time.
Old Jan 26, 2010 | 10:07 PM
GreenGoblin's Avatar
The goblin resurrection
I think I had that size easy out and it bottomed out on the crank pushing it out.
Old Jan 27, 2010 | 12:01 AM
the_sedan's Avatar
they have pilot bearing removers available at parts stores for rent. just a lil 2jaw tool that expands to catch the backside of the bearing and you use the slide hammer to pull it out. easy. takes a whole 10 seconds to do with the right tools.
Old Jan 27, 2010 | 08:01 AM
GMcAfee35's Avatar
I will check on that tonight...thanks!
Old Jan 27, 2010 | 03:01 PM
Tollboothwilley's Avatar
+1. I went to Checker and used a puller they had for rent
Old Jan 27, 2010 | 07:02 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry for the noob question, but what is a pilot bearing and what does it do?
Old Jan 27, 2010 | 07:19 PM
Jeff92se's Avatar
Red Card Crew
It helps align the clutch disc when installing a new unit.
Sometimes the input shaft of the tranny extends into that bearing but not always. On the old maxima it did not.
If the G does not, it really gets no wear at all. Not sure why the OP is pooping it out.
Old Jan 27, 2010 | 10:13 PM
GMcAfee35's Avatar
Worked like a charm...thanks
Old Jan 28, 2010 | 07:02 AM
Blue Dream's Avatar
Thanks Jeff.
Old Jan 28, 2010 | 04:15 PM
I believe the tranny input shaft does in fact reach into the pilot bearing on the G/Z. I only changed it on my friends Z cuz it came with the JWT kit that CZP was selling.
Old Jan 28, 2010 | 11:28 PM
DP03G's Avatar
I have used the two and three prong pullers on many and they never seem to work worth a damn. Packing it with grease and using a punch has worked on the most stubborn so far for me. Seems that the newer cars do not have a lot of surface to bite with the pullers from what I have found.
Some come out easy and others will fight you for hours.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
