Spark plug help..How tight should they be?
Old Feb 4, 2010 | 05:27 PM
jalonzo43's Avatar
I have read some threads and some people are saying that they should be tightened at 18ft-lbs and 20ft-lbs. Does anyone know what it should really be at?
Old Feb 4, 2010 | 06:15 PM
superchargedg's Avatar
You tighten them by hand until they feel tight then give a 1/4 of a turn.
Old Feb 4, 2010 | 06:19 PM
thescreensavers's Avatar
Mr.202?
11) Replace the spark plug with your new plug! Torque the plug to 20 FT-LBs! Make sure not to crossthread or overtorque the plugs! Aluminum heads are easy to strip out!
Old Feb 4, 2010 | 06:26 PM
Jeff92se's Avatar
Red Card Crew
In reality, the difference inbetween 18-20ft/lbs is small. whatever torque wrench you use is probably has an effor factor close to +/- 1lb
Old Feb 4, 2010 | 06:39 PM
bythabay's Avatar
The service manual says 18ft lbs, however, if you use anti-seize, you should drop that # by about 20% (result = ~15 ft lbs).
Old Feb 4, 2010 | 08:47 PM
jalonzo43's Avatar
thanks for your guy's help. I'm gonna change them Saturday and I just wanted to make sure
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
