engine lasting
Old Feb 7, 2010 | 02:24 AM
whoisthis's Avatar
engine lasting
any of you guys know how long can an engine last from time-to-time drifting?
Stock engine.
My car is 06 G35 coupe. How about VQ-35HR engine?
thx
Old Feb 7, 2010 | 02:48 AM
KSWAY's Avatar
from 1 time to 1000x's...
Old Feb 7, 2010 | 03:08 AM
whoisthis's Avatar
did u drift alot?hard?
Old Feb 7, 2010 | 11:42 AM
Tollboothwilley's Avatar
depends on how good you are at drifting. Stock motor mounts are pretty strong. If you do it a lot you might wanna consider some better ones though...or at least changing them from time to time.
Old Feb 7, 2010 | 01:11 PM
whoisthis's Avatar
i'm a beginner now. Changing as in modifying blocks and stuff like that?
what's the most common with that breaks in the engine when drift too much?
Old Feb 7, 2010 | 02:16 PM
do you know what an engine mount is?
do some research here and my350z.com
tons of information
Old Feb 7, 2010 | 04:30 PM
whoisthis's Avatar
i think i do... a mount that holds the engine. But i'm talking about the things that could break inside the engine like- block or piston.
Old Feb 7, 2010 | 09:31 PM
whoisthis's Avatar
Originally Posted by HomieG35
In stock form the VQ should be able to put up with the abuse of high revs. Get some supporting cooling mods, change your fluids more then often (you know, like don't get two hard drift sessions on the same oil change, or change your oil right after a drift day).
Generally speaking the ring lands go pretty easy. But on the stock 230-ish whp the block and rods don't suffer many failures.
You need to concentrate more on things like what TollBooth was talking about. The mounts, bushings (duh, suspension), and rearend and tranny are things you need to be beefing up.
thx i should made a thread of how long can a tranny n clutch last lol...
anyone wanna answer here
Old Feb 7, 2010 | 10:33 PM
whoisthis's Avatar
thx so much!
Sepsis
Feb 12, 2020 02:05 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
newg37
Jul 26, 2015 09:32 AM
