do the later vq35de's fit into the 03-04?
Old Feb 11, 2010 | 11:54 PM
sgostisha's Avatar
I need to replace my motor and found a vq out of an 06 350Z. how hard would it be to swap out? can it be done? How about a vq out of a nissan?
Please help!!!
Thanks
Old Feb 12, 2010 | 12:09 AM
Neu Era's Avatar
same motor. dont know if the 06 will fit the 03-04 transmission though.
Old Feb 12, 2010 | 07:26 PM
Canadian's Avatar
Canada, eh?
Yeah they're the same motor, will fit just fine. The only problem you will run into is if you buy a rev-up motor, then I'm sure it won't work.
Old Feb 13, 2010 | 12:01 PM
Shakuya88's Avatar
Trans is the same since it's the same block.
If it is a rev-up then all you'd have to do is also replace your main engine harness and ECU. If the car it came from is 05-06 350Z Manual, 05-07 G35 Manual It's a rev-up It's the trans is auto on any of those, your good to go
Old Feb 13, 2010 | 11:38 PM
sgostisha's Avatar
thanks
I got an 03 -04 non revup. I found on on ebay for 900. I dont know what is gone in mine yet but I dont think it is so bad I will not be able build it up the way I want.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
mbe32
Nov 13, 2015 11:09 PM
Claudiu
Sep 26, 2015 01:04 PM
