pulley issue
Old Feb 12, 2010 | 05:23 PM
805g's Avatar
Question pulley issue
so i believe that my issue is a bad pulley. I get high squeals at cold temps when the car hasn't been running.
I have UR pulley set installed and the ac idler pulley is either not lubed enough or could be outright bad.
Is there a simple test to see if the pulley is bad? and/or what type of lube should be used?
I feel that it needs lube, should it be placed inside the outer spacer?
all the help is greatly appreciated!
Old Feb 15, 2010 | 10:05 PM
techi13's Avatar
i'm pretty sure its not a bad pulley...and the noise you hear is very common
after initial install, the belts expand a bit longer and all you need to do is have the pulleys adjusted so the belts sits a little tighter
Old Oct 8, 2010 | 01:58 AM
805g's Avatar
so i can now tell that it is the pulley.
What type of lubricant should be used to make the pulley function smoothly?
Old Oct 14, 2010 | 09:55 PM
805g's Avatar
come on, i know it's an old thread....bumpity bumpp
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
EricF
Aug 28, 2015 08:27 AM
linedr89
Aug 17, 2015 05:11 PM
