stillen supercharger swap help!!!!!!
Old Feb 18, 2010 | 04:45 AM
thaistyle's Avatar
can you swap a supercharger stage 4 from a 06 g35 coupe to a 03 g35 coupe? talked to stillen and the ladie there said there was too much info to look over to tell, i was like wow thanks
Old Feb 18, 2010 | 09:27 AM
thaistyle's Avatar
Someone HEEEEEEEEEEELP!!!!!!!!
Old Feb 18, 2010 | 11:18 AM
skyvspecr34's Avatar
the kits are a little diff. the 06 one is set up for the rev-up motor if you go to stillens page it will show the some info for you. the best bet is call them back talk to the tech department i believe the guys name is steve(infitini tech). there charger are setup diff for 6speed and auto also for rev-up and non rev-up motors.
like i have a 03 6speed kit on a 04 which seems to pull alittle more power out of the set-up says stillen.
good luck with the set-up i hope it works out for you deff a fun kit
Old Feb 18, 2010 | 02:37 PM
4DGS's Avatar
It won't swap over, the rev up kits don't fit the pre rev up cars.
Picture Share
Feb 4, 2018 12:41 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
9tray turbo
Sep 29, 2015 10:22 PM
