How hard is it to switch out motors, mine blown
Old Mar 2, 2010 | 08:24 PM
jwrape's Avatar
My timing belt gave out and now only my crank is turning. I'm certain it destroyed the valves. I've switched out older motors 350 chevy, Honda, Nissan pickups. How hard is the G to do a swap yourself? Is it plug and play?
Old Mar 2, 2010 | 08:33 PM
jwrape's Avatar
Also need a good place to get a lower mileage used motor in Georgia
Old Mar 2, 2010 | 08:35 PM
sammy_G's Avatar
considering that your car doesnt even have a timing belt... i'd take it somewhere
Old Mar 2, 2010 | 08:42 PM
dann1313's Avatar
yeh its timing chains bro
Old Mar 2, 2010 | 08:50 PM
GeezNuts's Avatar
Old Mar 2, 2010 | 09:34 PM
jwrape's Avatar
Either way. I know when EITHER belt or chains are broken. I am familiar with the sound and the characteristics. I'm taring it down tomorrow to verify but the engine shut off and when turning over it has NO resistance(No Compression). Sounds like and feels like ONLY the crank is spinning. The crank turns but nothing happens. I know it's trashed. I should have known it was delicate at 130k miles. The guy I bought it from said he had the timing chain replaced. He lied.
I need another motor and someone who has done it before to tell me if it's a normal motor swap or is it more complicated. I have swapped a half dozen engines in my 33 years but every car is different. Is there anything I should watch out for or can I unplug and label and pull and re-install a new(used) motor?
Old Mar 2, 2010 | 09:46 PM
Glex25's Avatar
Administrator
http://my350z.com/forum/engine-drive...y-removal.html
Old Mar 3, 2010 | 12:22 AM
Dragon350GT's Avatar
No offense, but if you need to ask about things to look out for in a swap maybe you shouldn't be doing the swap. I've probably done more swaps than you and never once had to ask that. It's as simple as taking it apart and putting it back together in a reverse order. Unless your swapping to a different motor altogether but unless you failed to mention that I do not believe you are. Anyway, whatever you decide, good luck.
Old Mar 3, 2010 | 01:04 AM
Addytdot's Avatar
Goodluck
Old Mar 3, 2010 | 06:40 AM
jwrape's Avatar
I knew someone would say that. No worries. I will be fine. Just asking about anything abnormal to look for. I am fully competant in swapping just thought I would ask about any speedbumps in the process before I dove into it since I haven't had to work on a G before.
Old Mar 3, 2010 | 06:42 AM
jwrape's Avatar
THAT's exactly what I was looking for. Thanks, it looks easier than the other cars I've done since the front core support is removable.
Thanks!!!
Old Mar 3, 2010 | 06:56 AM
JOKER's Avatar
CLUB MODERATOR
I have a feeling that it's not your chain or motor.
Check started and flywheel
Look how tightly chain packed in there.
If it would have snapped you know how much noise you would have heard? And I bet your car should shake like a mother fvcker.
If your piston or rod went out, it's also easy to check.
Simply pop the oil pan and check for metal in the pan.
But I doubt anything is wrong with your motor (unless you ran it with no oil and friend the rings).
Old Mar 3, 2010 | 07:00 AM
jwrape's Avatar
Hmmmmm, there was a loud box of rocks sound. Like something let loose. I know the HB came off and is sitting there. The car shut off immediately.
When I turn over the car there is no resistance at all, no compression. If the chain was intact it should feel normal when turning over instead of just the starter spinning. The crank is spinning when the starter spins it but thats it.
I don't see any other way it would act like it is. But I will check it out after work today to be certain but I am sure it is broken.
Old Mar 3, 2010 | 08:36 AM
GreenGoblin's Avatar
The goblin resurrection
I suggest downloading the service manual, so you have all the torque specs for everything.
Old Mar 3, 2010 | 08:37 AM
jwrape's Avatar
Foudn it
