Engine Cover Screws are Broken HELP !
Old Sep 11, 2004 | 12:02 PM
BombRush's Avatar
I was trying to install Z-tube and K&N filter . In my first step i broke a screw which tightens the engine cover. Is there anways that I can get it fixed?
Old Sep 11, 2004 | 01:50 PM
lowrider's Avatar
Re: Engine Cover Screws are Broken HELP !
Either drill is out, or use an easy out. It's not a big problem.
If you ask me if I've ever broken a bolt on my Coupe while working under the hood, I'd have to answer yes. It just took time to get the darn thing out, and go to the hardware store for a new bolt. I drilled mine out using successfully larger bits until I reached the threads, then I blew out the residue from the old bolt, and used the new one as a tap and chaser.
Lou
Old Sep 12, 2004 | 12:04 PM
BombRush's Avatar
what should i do to fix it? should i just take it to dealership?
Old Sep 12, 2004 | 12:46 PM
lowrider's Avatar
Thought I answered the question?????
Lou
Old Sep 13, 2004 | 05:57 AM
neffster's Avatar
Bombrush,
Here's what you do. Go to Home Depot and buy an "Easy Out" drill bit set. You need to know the size of the screw, so take the other screw (the one you didn't break) with you to Home Depot. Ask a sales person to show you where they keep their easy outs and he'll give you the right size.
Read the instructions on the box and follow them. This will allow you to remove the broken screw from your car.
Don't forget to buy another screw at Home Depot while you are there to replace the broken stock screw. There is a chance that you'll have to buy the screw from Infiniti, or you could take a photo of it and maybe I could send you one of mine.
PS- too bad Lou didn't offer the same advice (j.k. Lou [img]/w3timages/icons/smile.gif[/img])
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Sep 16, 2004 | 01:27 PM
Saridi's Avatar
How long does it take for you guys to take out the screw? Yesterday I found that my engine cover screw is broken too. So I bought the screw retractor from Home Depot. And I've spent half an hour to drill on the screw.....and nothing really happening....[img]/w3timages/icons/frown.gif[/img]
My car
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
joedaddy1
Jul 28, 2015 02:58 PM
