Is there a correct answer to this or not?
Old Mar 18, 2010 | 02:34 PM
bigc's Avatar
Wings Nation
Originally Posted by djamps
So your positive? If so, what does it NOT reset that a dead battery does? Do you have something to back it up?
it doesn't reset fuel trims. once you're in CLFC the ecu uses the o2 sensors to keep you from running too rich or too lean. it remembers the adjustments even through a peddle reset. when i originally had my car reflash tuned, the ecu kept leaning out. since my tuner was out of the country, he had me do the 'hard', battery resets since the peddle reset would not take the car back to the base reflash & fuel trims. the battery reset wipes out everything the ECU has learned.
Old Mar 18, 2010 | 02:48 PM
headshot's Avatar
bigC, do you lose your radio setting etc... when doing yours. I didn't.. Is this normal
Old Mar 18, 2010 | 04:07 PM
bigc's Avatar
Wings Nation
iirc, u don't lose your radio settings with a pedal reset, but you do lose them with a battery reset. i only listen to CDs and the stuff on my ipod (radio sucks these days) so i don't really pay attention to it.
Old Mar 18, 2010 | 04:10 PM
headshot's Avatar
Well I wonder why I did not lose my settings after the battery reset? I disconnected the negative terminal for 15min then depressed the break peddle several times for 30 seconds each time and reconnected and the radio stations and blue tooth was still set. What gives?
Old Mar 18, 2010 | 04:12 PM
bigc's Avatar
Wings Nation
i'd press the brake pedal immediately after you disconnect the negative terminal of the battery, then wait a few mins before reconnecting. your short trip mileage meters (A & B) should also reset.
Old Mar 18, 2010 | 04:19 PM
headshot's Avatar
ok, thanks i will try it again and see if that it.
Old Mar 18, 2010 | 08:00 PM
headshot's Avatar
Tried it and still have all my radio settings. My trip mileage "did" reset back to 0. Is it possible there is a capacitor inside the radio that holds on to a little power and it maintains the radio stations? How else can I tell if the ECU reset?
I did the peddle thing and everything work out, but my radio stations were still there also. Any other suggestions.....
Old Mar 18, 2010 | 08:14 PM
bigc's Avatar
Wings Nation
weird, don't know what to tell you man. what year is your G?
Old Mar 18, 2010 | 08:27 PM
headshot's Avatar
2008, maybe its a special model lol
Old Mar 18, 2010 | 08:30 PM
bigc's Avatar
Wings Nation
you're in a whole different generation of G from most of us
fwiw, if your trip meter reset then you're probably good to go. was there a particular reason why you wanted to reset your ECU?
Old Mar 18, 2010 | 08:53 PM
headshot's Avatar
No not at all. Just kept reading that resetting it would cause it to lose its memory. Just wanted to see how it runs from a clean swipe. Really no reason, no problems. Putting the hypertech sport programmer in this Saturday. Just wanted to reset it before install. Also understanding no reason to, the G will accommodate for it in a matter of minutes and make the adjustments on its own (from what I am reading).
anyway, thanks for your time and replies
Old Mar 18, 2010 | 09:09 PM
Epidel's Avatar
hhhmm i forgot about resetting the ecu, its been a while, I think i am going to try one of these steps in th next few day s
Old Mar 18, 2010 | 10:05 PM
headshot's Avatar
Well do #3, this seems to effect the ECU more than #1. #1 seems to be a partial reset.
Old Mar 19, 2010 | 06:32 AM
PerpetualVisitor's Avatar
i only do #1 because i don't like losing radio settings, since I just moved my car to LA and I don't know the stations. If it doesn't reset everything, maybe I should just buckle down and battery reset O_o?
Old Mar 19, 2010 | 06:34 AM
  #30
headshot's Avatar
LA as in Louisiana? what part?
