Oil on a spark plug!!! what to do???
Old Apr 12, 2010 | 07:23 PM
angel_eclipse98's Avatar
Exclamation Oil on a spark plug!!! what to do???
So I recently just bought a '03 g35, just hit 104k, so I had to change my spark plugs & wiring boots but as I was changing it I found 1 spark plug full of oil!! Need advice on what to do??
Old Apr 12, 2010 | 07:26 PM
WhosRich's Avatar
You got extended warranty on it? If not, it's going to be expensive. Leaky valve cover.
https://g35driver.com/forums/g35-cou...rranty-up.html
https://g35driver.com/forums/g35-sed...rranty-up.html
Old Apr 12, 2010 | 07:29 PM
thescreensavers's Avatar
Mr.202?
I hear now they just replace the gasket?
Old Apr 12, 2010 | 08:41 PM
OCG35's Avatar
throw the car away - it's no good now.
Old Apr 12, 2010 | 08:54 PM
Kris79's Avatar
battle froggy
change the gaskets and plugs and ur good.
Old Apr 12, 2010 | 09:09 PM
OCG35's Avatar
what gaskets?... if you mean the seals - they aren't replaceable...
This entire topic has been discussed at length - in many threads...
OP - here's the most relevant thread:
but if you do a search you'll find many threads about your issue.
Old Apr 14, 2010 | 04:53 PM
okay so why would I do that!?! when all i need to do is replace the cover gaset set???
Old Apr 14, 2010 | 04:56 PM
So how bad would it be driving around with oil on a spark plug??
Old Apr 14, 2010 | 05:30 PM
OCG35's Avatar
no, the car is no good anymore... throw it away.
Old Apr 14, 2010 | 07:56 PM
why do you say that tho?? I've been doin a lot of research and the experts say its a very common problem on the vq35 engine, they also told me to just replace the plugs and gasket and I should be okay... I don't understand why you would say that w/o any edvicence???
Old Apr 14, 2010 | 09:29 PM
OCG35's Avatar
^^^ common... do you really think I'm serious???? I mean really - "throw away the car"???... it was sarcasm man - the issue you are dealing with has been talked about for years... you need new valve covers (there is no gasket and you cant replace the seals).
I can't believe you really thought throwing the car away is a serious recommendation.
btw, did you bother to read the thread I linked for you in post #6?
Old Apr 15, 2010 | 02:12 PM
bythabay's Avatar
what is all this talk about replacing the spark plug tubes seals? They are not replaceable as they are part of the valve cover (dumb design). If There are new seals available that with the the oem covers, I'd like to know about it,and so would everyone else
Old Apr 15, 2010 | 02:23 PM
Okay so I found the valve cover gasket I need and may also help anyone else with the same issue. I found it for $17.99 at O'Reilly Auto Parts! btw ocg35 did you actually think I took that recommendation seriously?!? Na man I jst figured u were just some hater tryin to talk some bs...
Old Apr 15, 2010 | 04:39 PM
OCG35's Avatar
gaskets aren't your problem... you need new covers (it's been mentioned at least 3 times already)... the seals are not replaceable - and that's what is causing the oil to pool up... you probably dont need both covers (unless you have plug on both sides leaking)... but replacing the gaskets alone is not going to fix your problem.
Old Apr 15, 2010 | 04:49 PM
Oh I just figured it was the same part... Where could I find these vavle covers? I think I would only need the right side cause its only the 6th one that has oil in it...
