Key Mod LED
Key Mod LED
Since I dont smoke, here is a mod I came up with for the ashtray. I have to use a special magnetic key to get into my parking garage so I made a custum holder with backlit LEDs.
Re: Key Mod LED
Power is already there. You may not have noticed with the black plastic but there is a small light incorporated in the astray. Just pull it out and you will see a small window in the removable part.
Just pull up the center console, and you can remove their dim LED / circut board and replace with your own LEDs. You dont even have to trun off the battery because there is a clip to unplug the power to the ashtray under the center console.
I also drilled out thier protective clear window so I could put the blue LEDs inside of the ashtray.
Re: Key Mod LED
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
