car died and wont start again?
It could be the alternator. Did you check the belts and pulleys in the front of the engine bay to be sure nothing snapped?? (I'm sure you would have noticed this though). If the alternator isn't working and your battery voltage is just below where it needs to be its possible. Only way to test is to try to jump your car and see what happens. If you can jump it you just narrowed down your problem.
Fuel pump is a definite possibility. I know on 03 Coupes and Sedans there was an issue where the fuel pump hose wasn't correctly clamped to the pump causing it to disconnect and not give fuel to the engine. If you have a friend present, I believe you should be able to hear a slight whine coming from the rear-right wheel area when the key is in the ACC or ON position (whine is the fuel pump). Have you checked for any fluids underneath your car? Included the position where it stalled at?
Theoretically the pump could still turn on and just not be pumping fuel. An unfortunate situation because it makes it difficult to diagnose, but I can't think of many things that would both 1) kill the car while it's running and 2) prevent it from starting up.
We can eliminate:
- Electrical: your car is trying to start, jumping it didn't help
- Starter: push starting it does nothing, starter is making noise and turning, plus the car died while running and the starter is useless while the car is running
- Spark Plugs: would cause a misfire unless 2 or more fouled at the same time (very unlikely)
- Sensors: usually the car will still start but it will stall out shortly after or throw a check engine light
Are you running an aftermarket filter or intake system? Either way, pull off your intake and check your MAF to see that a) it's still connected and b) not dirty. If you're running a K&N (or any other wet filter) it can cause your MAF to become very dirty which could theoretically stall the car or not allow it to start.
The only way to really eliminate the alternator is to try to jump from a running car. Battery chargers are only going to provide 12v as far as I know, a running car with a good alternator should provide approximately 13.1v+ and should allow you to start your car. Not sure if a battery charger helps a bad alternator, never tried.
We can eliminate:
on
i have a kn cold air kinetix plenum i can check the maf
but if the maf is messed it will stall the car and not allow it to start? because i think the maf was sitting really close to the a/c line and it looks like one of the wires is a bit damaged the coating but i turned the maf a bit so they wouldnt touch
#30
If the MAF is essentially not pulling a reading it could cause the car to stall. The MAF with ANY aftermarket filter or intake sits close to the A/C line and can rub against it and cause damage to both the MAF harness and the A/C line. As long as the wire seems to still be in one piece you should be fine. But definitely check to see if it's still clean
Usually a bad MAF or throttle body would cause a rough idle before it got this severe, but it is possible that the MAF simply stopped working because of the harness wires being damaged or the MAF being too dirty.
Not a guaranteed solution, but still possible.
