AWD grounding wires
Old Apr 18, 2010 | 05:57 PM
ccc123pm's Avatar
X
AWD grounding wires
So I was doing some maintenance on the car and I thought it would be a good time to get the transmission grounding wire on. I have one from Sean (SxExCx) on here and located the suggested grounding point. The only problem is, there is the front driveshaft right there. There is literally about a 3/4" space between the transmission case and the driveshaft and the bolt is about 3 inches up.
For those that have installed this, any advice or suggestions would be appreciated.
Old Apr 18, 2010 | 06:12 PM
davidxu's Avatar
i put mine to this point
Old Apr 18, 2010 | 11:01 PM
ccc123pm's Avatar
X
that looks like it is right in front of the black tranny pan?
Old Apr 18, 2010 | 11:17 PM
drkay's Avatar
i put mine here, but i don't think its grounding anything there as there was no difference in the shifting on the A/T at all. davidxu, did you notice a difference when you put the wire there?
thanks
RWD G35x, Motordyne 5/16" Copper Iso Thermal Plenum Spacer, Z-Tube with Pop-Charger, NGK Iridium with Mobil 1 Synthetic, EBC Green Stuff Pads with EBC 3GD Sport Rotors, Brake Master Cylinder Stiffener, OEM Spoiler
Old Apr 18, 2010 | 11:26 PM
davidxu's Avatar
a slight bit. Not day and night difference though..
Just mount it anywhere on the tranny housing but away from heat components or moving parts.
do an ecu reset after.
if i shift while WOT and i shift at 6500rpm, it used to shift at 7000RPM or over. Now it shifts at around 6800RPM
Old Apr 18, 2010 | 11:27 PM
ccc123pm's Avatar
X
Is that on the driver side of the tranny?
Old Apr 18, 2010 | 11:31 PM
drkay's Avatar
yes i believe mine was in the drivers side of the trans but it was a while ago. . .i remember it was hard to get at
RWD G35x, Motordyne 5/16" Copper Iso Thermal Plenum Spacer, Z-Tube with Pop-Charger, NGK Iridium with Mobil 1 Synthetic, EBC Green Stuff Pads with EBC 3GD Sport Rotors, Brake Master Cylinder Stiffener, OEM Spoiler, Grounding Kit
Old Apr 18, 2010 | 11:32 PM
davidxu's Avatar
My picture is on the pass side.
Old Apr 19, 2010 | 07:05 PM
ccc123pm's Avatar
X
yeah, figured with the driveshaft right there
Old Apr 25, 2010 | 06:19 PM
ccc123pm's Avatar
X
can this be moved back to V35 sedan forum, its been dead since it was moved here
Old Oct 11, 2010 | 11:52 AM
ccc123pm's Avatar
X
Still havent found a good spot to put the AT grounding wire. Any other suggestions
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
