grounding 6th wire
Old Apr 8, 2003 | 04:48 PM
Scoop's Avatar
grounding 6th wire
BillR
Can you tell me where the 6th wire starts and ends.
I made up the other 5 wires and installed them but though I would like to add the 6th
Thanks in advance
<font color=blue>[b]G35c DG/leather 5AT 18"wheels Tint.... The car in your mirror will fade quickly
Old Apr 8, 2003 | 08:41 PM
Msedanman's Avatar
O.F. Administrator
Re: grounding 6th wire
Hey bro, I think that's the one that goes down to the tranny. I read somewhere about that. If you've installed the kit, just pick a convenient spot to hook it into, (maybe the connecting point at back of the intake) and run it down to a reachable spot on the tranny housing. Let me know what you find out and how you do. I'd like to do that too altho I'll have to make up a 6th wire. Let me know the length......L8r
[img]/w3timages/icons/smile.gif[/img]
<font color=green>GSM</font color=green>
Old Apr 9, 2003 | 05:56 AM
Msedanman's Avatar
O.F. Administrator
Scoop, I contacted InSaNeAmine again about the 6th wire. He sent back instructions on it's length and connectng points.
Apparently it's 30" and connects to the point at the rear of the intake -right side- and runs down to the air box hold down bolt next to fender. If you'd like to P/M me your email, I'll scan a copy to you.
I'm also working on a 7th wire to run from that same point down to the tranny. L8r bro.
Old Apr 9, 2003 | 08:32 AM
BillR's Avatar
Partially right,
I does connect to the intake, but runs ove to the factory ground point on the drivers side strut tower. You will see the bolt for the factory ground site if you move the factory wire harness.
BillR
G35C Laser Red, Prem, Nav
Old Apr 10, 2003 | 07:34 PM
Scoop's Avatar
Hey GSM & BillR
Made up my 6th wire today and installed it.
Can't say I see any difference but it looks good
Thx to both of you for all your help
Scoop
Old Apr 10, 2003 | 09:21 PM
Msedanman's Avatar
O.F. Administrator
Re: grounding 6th wire *DELETED*
See Post below<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 04/11/03 05:49 AM.</EM></FONT></P>
Old Apr 10, 2003 | 10:29 PM
Gordgee's Avatar
Administrator
Why the tranny filler tube bolt? I thought about crawling around under the car this W/E and seeing if there is a good spot to ground directly to the tranny housing.
<font color=green>GG</font color=green>
Old Apr 10, 2003 | 10:35 PM
Msedanman's Avatar
O.F. Administrator
I spent some time looking this morning under there bro. But go ahead , give it a try. Don't see the point tho. Why go way under there if there's a handy spot up top?
Old Apr 11, 2003 | 08:47 AM
Msedanman's Avatar
O.F. Administrator
Thanks Bill, I found the factory ground point on the D/S strut tower.
I contacted InSaNeAmine in La. today about the 7th wire to go from the Left rear of the Intake (same point as #3 wire) to the tranny filler tube bolt. *see the attached pic*. It's only a 10" wire. I've forwarded pics to InSaNe to revise his instructions. He'll ship #6 & #7 tomorrow for me. I'll post pics when they come in.
Not sure yet where #7 will terminate on manual trannies. Gotta have a look at manual settup.
Scoop: your very welcome bro. glad to help
L8r bros.....
Old Apr 11, 2003 | 10:38 AM
GIlovemycar's Avatar
Do you installation directions that you could email me?
Old Apr 11, 2003 | 06:43 PM
Msedanman's Avatar
O.F. Administrator
Sure dude, just P/M me your email........[img]/w3timages/icons/smile.gif[/img]
Old Apr 14, 2003 | 05:48 PM
lebushaw's Avatar
I wouldn't mind having those install instructions too?????
Larry Bushaw lebushaw@rockwellcollins.com
Old May 9, 2003 | 01:16 AM
gr4n23's Avatar
Can somebody email me the instruction too plzzzz
m.santoso@verizon.net
Old May 9, 2003 | 08:26 PM
Msedanman's Avatar
O.F. Administrator
It's on it's way bro-- and good luck.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
