radiator fan always on?
ok so I just got my car back from the body shop after getting a new front bumper, air con condenser and some other minor work done and while driving back i noticed my radiator fan is constantly running. they did drain the coolant and replace and drain and recharge my airconditioning. is there any way the body shop guys could have reconnected something incorrectly? is this something i can check/fix easily or any other ideas? I really would prefer not to have to take the car back to the body shop if it's an easy fix.
yeah, problem solved this weekend. they did not bleed the system correctly and I spent several hours bleeding it. amazing what a few air bubbles can do to your cooling system...
I had this same problem, so I also used the air purge valve but air kept getting in, ended up being my radiator cap. $15 part fixed everything. I also replaced my thermostat and the dealer changed both my radiator fans, which they are reimbursing me for now.
Air in my coolant system made everything go crazy, temp gauge going all over the place and my heater not working, also made my radiator fans run at full speed 24/7
So my advise to people with overheating G's is to replace the radiator cap and purge the air out of the system and fill your reservoir to the MAX line.
04 G35 coupe A/T
30K miles
04 G35 coupe A/T
30K miles
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
lavtxa
Sep 21, 2015 11:51 AM
