MREV2 - remove stock lower plenum HELP
Old May 14, 2010 | 03:03 PM
Yv12345vY's Avatar
Exclamation MREV2 - remove stock lower plenum HELP
Trying to install the MREV2 and the stock lower plenum won't budge. Any ideas on how I can remove it?
Old May 14, 2010 | 03:08 PM
Trigo's Avatar
search DIY or Mrev2
Old May 14, 2010 | 03:30 PM
Yv12345vY's Avatar
Thanks, that's the first thing I did but didn't find an answer.
Anybody have ideas/suggestions?
Old May 14, 2010 | 03:34 PM
Trigo's Avatar
http://www.myg35mods.com/tutorials/spacer/index.html
Old May 14, 2010 | 03:35 PM
Yv12345vY's Avatar
Sorry but where does it say how to remove the lower plenum if it's stuck?
Old May 14, 2010 | 03:56 PM
SxExCx's Avatar
I would guess that you didnt remoce the 2 nuts on the front and rear..or it is just stuck on the threaded posts...wiggle it a bit.
Old May 15, 2010 | 05:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Should be an easy removal. IIRC it's only held down by 4 nuts. Check what Sean recommended. ^^
Old May 15, 2010 | 06:28 AM
Yv12345vY's Avatar
I'm pretty certain I took all the bolts off. The sucker wouldn't budge. I found a rubber mallet though!
Old May 15, 2010 | 07:32 AM
LMG_35C's Avatar
I count eight bolts in the lower plenum to be removed. There was absolutely no issue when I replaced mine.
Old May 16, 2010 | 03:29 PM
Blue Dream's Avatar
You're right. I think I had a brain fart.
jsimonk
Dec 22, 2023 03:49 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
skippyG
Jan 25, 2016 01:18 PM
