engine rebuilding ideas
Old May 20, 2010 | 11:42 PM
fatlip's Avatar
Ok so i might have an OC issue but havent confirmed yet. So that said im thinking of rebuilding the motor. If the cylinders are ok then ill stay with the factory size pistons. If not then bore it out and go over size, High compression either way since ima keep it NA.
Since im only rebuilding the block I figure ill need:
Pistons/rings
rod/main bearings
gasket set
Labor is gona be free except if i have to bore it out. How does that sound so far? Anything else i should add?
mtlruss
Dec 20, 2015 01:51 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
slider_ua
Jul 29, 2015 04:17 PM
