car going into limp mode
Old May 27, 2010 | 01:07 PM
speedlab's Avatar
i have a 2005 g35 coupe auto with a vortech supercharger has been running great but goes into limp mode pulled codes p1122 and 1126 i have changed the throttle body and mass air sensor car will run for 10-15 mins and then go back into limp mode can anyone help me dont know what else to do
Old May 27, 2010 | 06:17 PM
djamps's Avatar
What EMS? I get those with my UTEC, I'm convinced after mass troubleshooting/replacing of parts it's caused by the UTEC itself.
Other than that, check all grounds on the engine.
Old May 27, 2010 | 06:35 PM
04G35NYC's Avatar
unplug the negative battery cable and wait for like 5 min put it back and drive around it should go away. My friend had the same problem but with out a s/c.
Old Jul 18, 2010 | 10:21 AM
speedlab's Avatar
limp mode
my car has been down for over 2 months now cant figure out whats making it go into limp mode we changed throttle body mass airflow sensor and ecu we checked engine harness still cant figure it out can anyone help need this problem fixed
Old May 6, 2023 | 07:09 AM
BeanBby909's Avatar
Infiniti g35
Limp mode
Ok I got a theory before buying all these car parts because your car is on limp mode check to see why by resetting any codes first then get ur car reprogrammed and then to be on the safe side reprogram your car keys drive the car for a few miles see if it drives better and if the check engine light pops back up check to see what codes it gives u now. Also check to see if your anti theft alarm is on even after unlocking your vehicle if it is that's what's causing your limp mode ur alarm is engaged.
Old May 6, 2023 | 10:36 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
This thread is 13 years old. You can't even start the car if it's a NATS anti-theft issue, it will NOT cause a limp mode.
Hasanbaloch
Feb 29, 2024 08:45 PM
hdmark
Apr 29, 2019 04:31 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
Cskeet
Jul 21, 2015 05:48 PM
