Need help about oil change
Old Sep 30, 2004 | 10:49 PM
acerys's Avatar
I will be doing transmission oil and defferential oil change soon, I prefer Motul synthetic, I know the trans oil is 75W90,but just confused about which defferential oil model I should go with and how many liters I need respectively.
Old Oct 1, 2004 | 09:08 AM
cato's Avatar
SouthernComfort Moderator
Re: Need help about oil change
Just have the dealer do it for you. Take them the oil you want
used.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
Old Oct 1, 2004 | 04:46 PM
acerys's Avatar
Can I put Motul 75w90 in both trans and LSD?
<P ID="edit"><FONT class="small"><EM>Edited by acerys on 10/01/04 02:09 PM.</EM></FONT></P>
Old Oct 1, 2004 | 07:09 PM
jdove's Avatar
You can but... the OEM Viscous LSD will be a little less effective with a full synthetic.With a mechanical LSD it's a different story, in that case both 6MT and Diff benefit from the synth. I prefer RP max in both, but I use a Cusco RS LSD.
Old Oct 1, 2004 | 07:50 PM
acerys's Avatar
Why synth makes less efficient?
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
