Where to ground Valentine 1?
Old Sep 30, 2004 | 11:10 PM
Aznteazer's Avatar
i tried grounding the wire behind the dead pedal, but my V1 goes on and off. apparently it's not making good contact.
where did u guys ground ur wires to? pic of where u ground them would be very helpful.
thanks
Old Nov 18, 2004 | 03:04 PM
nizmo's Avatar
Re: Where to ground Valentine 1?
here's a good site with good pics on the stealth installation on a sedan.
nizmo's Avatar
http://www.g-owners.com/article_read.asp?id=3
Old Nov 18, 2004 | 05:04 PM
afr0puff's Avatar
Supa Dupa Moderator
Try the fuse box also. You will probably find an empty screw hole. Or something that is already grounded there. They can share
Old Nov 19, 2004 | 12:21 AM
ZeroGen's Avatar
Omega Enthusiast
I grounded my V1 on a screw above the driver's side fuse box. When looking at the fuse box, look up and you should see two gold colored screws that screw into sheet metal. You have to reach in with a Philips screwdriver but it's a good ground. Also, you'll have to bend the ground spade lug open quite a bit to fit around the screw.l
04.5 G35C TB/Graphite 6 speed, XM Radio, Premo Package, Navi, OEM Chin Spoiler, Hard wired V1
Old Nov 20, 2004 | 08:32 AM
Meatshackle's Avatar
Deep Sea Moderator
There are a couple of good screws under the lower console cover on the driver's side. They hold the metal frame below the steering wheel.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
JustinMKN1
Sep 18, 2015 03:40 PM
