Do i need my crank case vent connected????
Old Aug 3, 2010 | 04:38 PM
jon121587@yahoo's Avatar
I was wondering if i need ed my crank case vent connected and reason for asking is because when i had switched my stock plenum with the kinetix SSV there was alot of oil reidue in some of the cylinders and i thought by disconnecting it it would pull cooler air in and no oil residue but dont kno if it is safe
Old Aug 3, 2010 | 07:05 PM
superchargedg's Avatar
Run a oil catch can setup and you will be fine.Our engines always have a small amount of oil in the plenum.
Old Aug 3, 2010 | 11:20 PM
so jus leaving it disconnected wont hurt though right?
Old Aug 3, 2010 | 11:23 PM
M3Tuner44's Avatar
You dont want to leave it unconnected because it can cause a vacuum leak. Hook up a catch can to your pcv and crank case and that oil wont be so noticable in your plenum anymore.
Old Aug 5, 2010 | 01:37 PM
HotRodG35's Avatar
Yes it needs to be connected. It helps prevent crankcase pressure buildup due to blow-by, prevents crankshaft seal leakage and oil contamination.
Marlin84
Apr 1, 2020 12:52 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
Learned Hand
Oct 1, 2015 09:02 AM
master111
Sep 25, 2015 08:32 PM
