Installed Crawford V5 Plenum
Old Oct 8, 2004 | 04:40 PM
jdbinspired's Avatar
I was just wondering if anyone else has experienced with happening... After installing the plenum with a Z tube and pop charger... started the car.. idle had like aknocking sound and the noise coming from the plenum was hollow and if I rev high afraid that the plenum might crack or break...?
Any feedback on this would be great....
Thanks
< aRTiFiCiaL iNTeLLiGeNCe iS nO MaTcH fOr NaTuRaL sTupiDiTy >
Old Oct 8, 2004 | 06:57 PM
G35pm's Avatar
Re: Installed Crawford V5 Plenum
Does the car stall after you start it? Make sure you have those two screws installed in the lower plenum. Any signs that the plenum looks warped? Maybe there's a leak?
Old Oct 8, 2004 | 07:23 PM
No... the car runs perfectly fine... It's just that... maybe it's in my mind but the sound makes the plenum sound soft like I can blow it up if i rev high...
Old Oct 8, 2004 | 07:46 PM
G35pm's Avatar
The Engine does get loud w/the plenum at high rpm. I've bounced off the rev limiter w/the plenum w/no prob. I remember I'd get scared at high rpm cause it would roar. Some of the guys that also have this mod say they hear a hollow sound sometimes. If you eventually get the TS ECU (to correct that lean condition that the plenum introduces, in addition to other benefits) flash the engine quiets down a bit at high rpm.
Old Oct 8, 2004 | 08:24 PM
G35pm: Hey Thanks Much for the feedback....
Jeremy...
Old Oct 8, 2004 | 11:09 PM
karlhungus's Avatar
I took my Crawford off for mainly that reason. I couldnt stand the tapping and weird intake sounds from the welded piece of aluminum resonating. I now have the stock plenum, Z-Tube, and drop-in K/N now and it sounds good and has great torque where it should be. Up to you, but I would ditch the Crawford and wait for the nice cast unit coming from APS. That looks to be a well-engineered unit instead of a cut and paste job.
Old Oct 9, 2004 | 02:48 PM
SixFive's Avatar
Use a hood liner to quit the bad noises..I have V-4 and it sounds like a mess until I put H-liner on it. The Z tune will maked it harder to hear anything from plenum.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Oct 9, 2004 | 04:46 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Man you guys make we not want to complete my modding with a plenum, hmmmmm
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Old Oct 9, 2004 | 05:17 PM
lowrider's Avatar
My Gosh
IMHO, The Crafword Plenum (was) and still is the best bang for the buck out there. I don't notice any weird nosies, but I have had my plenum for a couple of years. First a V2 and now a V5. I changed for cosmetic reasons only. It evens out the mixture problem and adds greatly to the midrange and high end. I do not and never heard any strange noises. With my intake (POPCharger and "Z" tube) and exhaust (custom pipes with a Magnaflow and resonators), at full acceleration there is a sound of power. At normal cruising speeds, it sounds quiet to me, however when I mash the throttle and down shift, all heck breaks loose. The car takes off, and the roar begins.
No, the "G" is not as quiet as my last car, a Lexus SC300 was, but it is a far more satisfying car to drive. This is a High Performance Automobile, not a Cadillac.
Again - The Crawford Plenum is great mod.
Lou
Old Oct 10, 2004 | 07:30 AM
neffster's Avatar
Yeah, everything Lou said and more. For those of you on the fence, GO TO A MEET! Drive with someone who has the setup and make your own mind up. Best performance mod I have, for sure!
Old Oct 10, 2004 | 10:55 AM
Madelinot's Avatar
I installed a Crawford V5 Plenum a few weeks ago. There is a slight tapping hollow sound to it. It does it more at mid RPM and when the engine is cold. Just as a point of reference, my wife did not notice anything despite the difference in sound. It's not bad for the slight HP increase...
Later,
Old Oct 11, 2004 | 01:14 AM
SoCalTed's Avatar
I'm wondering of you caught the oil-fill cap's gasket in the plenum when you were cranking it down. That's a pretty common mistake.
V5 do have a little more noise, but not unconfortably so. Di you use the double gasket method, or just use the single that came with the plenum. Most of us use the and old gasket together.
Cheers, Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS - www.teamtransport.org/forums
Old Oct 11, 2004 | 02:14 AM
hey everyone... Thanks for all the feedback... yeah.. I did have some trouble with that rubber piece around the oil cap... I used a flathead to move it out of the way while i layed the plenum down... and yeah i did use the the old gasket and the one that came with the plenum...
Old Oct 11, 2004 | 05:42 AM
neffster's Avatar
Madelinot,
If you want to turn that "slight HP increase..." into a REAL NOTICABLE GAIN, throw on some high flow cats (or straight pipes if you can handle the sound). Those 2 mods together are good for ~15rwhp. [img]/w3timages/icons/smile.gif[/img]
Old Oct 11, 2004 | 01:14 PM
Madelinot's Avatar
I will probably change the cats next. Do they make any difference in sound?
