redline??
Old Sep 8, 2010 | 07:42 PM
jayflyxx's Avatar
redline??
i was gettin on the highway today in manual mode and i took off and ended up at 7000 rpm at fuel cutoff in the redline.. is that bad enough to ruin anything? it was only there for like 10 secs..
Old Sep 8, 2010 | 07:46 PM
biggz786786's Avatar
why was it up there for 10 whole seconds?
SN00P's Avatar
CLUB MODERATOR
^^ im sure he forget about it ...
Old Sep 8, 2010 | 07:48 PM
4D05G35's Avatar
10 seconds? you were bounding off the revlimiter/fuel cut-off for 10 seconds? What were you doing between seconds 2 and 10 to not know that you were bouncing off the rev limiter.
Old Sep 8, 2010 | 07:57 PM
SN00P's Avatar
CLUB MODERATOR
radio up full blast and texting on the phone LOL
Old Sep 8, 2010 | 08:44 PM
TurTLe*'s Avatar
bouncing off the rev limiter is acceptable.
holding it there for 10seconds is a COMPLETE IDIOT would to. Just stay away from manual mode from now on.
Most likely the ECU protected your car by obviously cutting off fuel, little to no damage was done mainly due to its a MODERN car, had you do this on an older car, its would of had some damage.
I wouldn't worry about it but please dont do this often. Everyone talks about MM all the time here and then i used it a couple times and hated it, but then i found out when you shift in MM your not suppose to lift off the gas. I was lifting off the gas and the car was jerking cause of it.
Old Sep 9, 2010 | 12:53 AM
NFSP G35's Avatar
? = 2B || !2B
10 Sec on the rev limiter... lulz
IDK about the G, but my friend's Subaru 2.5RS took constant abuse on the rev limiter every single day for years.
In the end, his tomfoolery wasn't what killed it, but rather a Chevy conversion van
I've hit the rev limiter plenty of times on the G, but never for 10 sec... you probably shouldn't make a habit of it.
Now the rental Camry on the other hand.........
Old Sep 11, 2010 | 02:40 PM
tdawgg's Avatar
Me too..
Hi guys,
No need to start a new thread here but I had the same kinda problem today with mine.
I was coming out of the grocery store and had to wait awhile(getting impatient) when a small opening came, I pounced on it. While turning the corner my hand slipped and I threw it into manual. I hit about 7000 before I shifted it back into auto.
My questions are..
This bad for the engine? probably not but Im asking you guys.
This bad for the tranny? not sure.
Car is an 06 g35x with 50k miles or 80k here in Canada.
Any input is appreciated.
Old Sep 11, 2010 | 02:52 PM
toymachine2009's Avatar
Originally Posted by tdawgg
Hi guys,
My questions are..
Read the above Posts ^^ it was just answered.... He said if its just a second its not a big deal ecu protected you and no damage was done.
Old Sep 11, 2010 | 03:01 PM
Mustang5L5's Avatar
I'm sure you are fine. Whenever I go to the drag way, the Honda boys leave their engines banging off the limiter for 30 seconds or more while their buddy "tunes" something under the hood.
I bang my limiter in 1st and 2nd all the time in my mustang. Tach can't keep up with the rpm climb and I hit it all the time. That's what it's there for...but try not to hold it there too long
Old Sep 11, 2010 | 03:03 PM
thescreensavers's Avatar
Mr.202?
many times my RPM needle will go a bit into redline, and its known that the tach can be upto 400rpm off.
Rev limiter is there to protect you, just shift
Old Sep 11, 2010 | 03:06 PM
tdawgg's Avatar
I was concerned about me shifting back into manual(I mean auto, haha) from 1st, but obviously its not a big deal.
How hard do you guys drive your g35s and what troubles may be associated with a heavy foot?
Old Sep 11, 2010 | 08:25 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
poor gas mileage trust me
Old Sep 11, 2010 | 11:21 PM
3truman's Avatar
bald rear tires
wanting more horsepower
just to name a few
Old Sep 12, 2010 | 02:18 AM
4D05G35's Avatar
To add to the above ..... unwanted attention from law enforcement. A heavy foot can easily lead to unwanted speeding/wasting natural resource tickets.
