DIY: "Cold" Air Intake
Old Sep 23, 2010 | 11:22 PM
HenryLee's Avatar
Learned a lot from this forum. So wanted to give back to the community. I didnt invent this, the concept and idea was already out there on the threads. I just wrote a DIY for people to see.
Although our intake boxes are open the hood actually closes most of the openings. This is just to improve the stock box. Dont expect significant gains, as this mod will give only minor gains, if any. It will just help open up some more free air. Here's my Rev-up airbox with Z-tube and "Cold" air mod.
1. The basic parts I bought. An Auto Vac hose, Drill bit, and pipe cap. Oh also some black spray paint and Clear since I didnt have any. Best $25 I spent.
2. Remove
3. Remove
4. Loosen or Remove
5. Cut here. Be careful.
6. How it should look.
7. Cut here. Be careful
8. Cut slowly.
9. It should be perfect. Nice and tight, and wont fall off.
10. Thread the hose through.
11. Thread the other end of the hose to the stock air box.
12. It never rains in socal but I bought a cap for those who live in Rainy areas.
13. Perfect time to clean your dirty Air filter.
14. Paint the white ring to black.
15. Also paint the cap if your gonna use it.
16. Finished product. Perfectly hidden.
Like I said, this is only to supplement your stock box. I have no proof of its gains, nor will I do anything try to prove its performance. This is only a DIY.
The only thing I can report from my butt dyno, is at high speeds it pulls harder. My exhaust sounds a bit louder and I "think" its faster. But then anything must help if it opens up more air. I hope the DIY helps. Its not a hard mod. If anyone needs help, I will do the install for anyone for $15 which includes supplies.
But mostly notice before I installed the grille back on, I closed the hood and could feel sucking pressure from the hose. All that matters for me, haha even if it doesnt work.
UPDATE:
Pictures with the funnel. The funnel helps so much. Its a pretty easy and great mod.
When to a local auto store, bought the liter funnel. Pulled the vacuum hose out. Threaded the funnel on the hose and installed the hose back into the car.
Old Sep 23, 2010 | 11:53 PM
jayk's Avatar
Nice write up Henry!
Might be more efficient with larger tubing and a funneled end to catch more air via the grill.
I am in the market for these OEM Parts!
Old Sep 24, 2010 | 12:13 AM
HenryLee's Avatar
^ Yea the biggest problem was finding larger tubing. I couldnt find a larger flexible vacuum hose. That was the largest I found.
Old Sep 24, 2010 | 12:22 AM
G35SedanGrn's Avatar
i wish i wasnt to lazy to do this haha
Old Sep 24, 2010 | 12:39 AM
antknee's Avatar
good and really affordable mod.. big ups henry!
Old Sep 24, 2010 | 03:28 AM
VictoriousG's Avatar
Hey Henry theoretically if you drilled a bigger hole behind the grill wouldn't that suffice to bring in more air? or is the hose really necessary? anyway great job bro!
Old Sep 24, 2010 | 09:11 AM
HenryLee's Avatar
^ Yea i technically it would work. But i was trying to prevent heat soak. The hose allows more direct "cold" air, where just having a bigger hole would combine the cold and engine air together. But what I need is a funnel like Jayk was saying. Need something to catch more air.
Old Sep 24, 2010 | 09:23 AM
alfhasg35's Avatar
yep.. a funnel.. nice job henry.. i did this exact mod on my tacoma almost 15yrs ago...
Old Sep 24, 2010 | 09:25 AM
HenryLee's Avatar
^ Haha 15 yrs ago? Thats sweet. Dang are you sure your not the creator of this mod? LOL.
Old Sep 24, 2010 | 02:48 PM
SxExCx's Avatar
^i'm sure he's not the creator of this mod on the G
Old Sep 24, 2010 | 03:21 PM
vp-g's Avatar
intresting.. if the tube came in black that would be nice...
Old Sep 24, 2010 | 10:56 PM
alfhasg35's Avatar
i wonder if this mod is why i got that couple of extra hp that put me over 300 on the dyno at church's
Old Sep 24, 2010 | 11:01 PM
HenryLee's Avatar
^ Over 300 n/a is really an acomplishment. I remember when people used to say it wasnt possible with just Bolt ons. Way to prove them wrong.
I just added a funnel today.
Old Sep 24, 2010 | 11:04 PM
kennymo's Avatar
i would keep the same size tubing and just get a funnel that you can attatch to it. and then have the tunnel mounted to the support. that way it will atleast have the funnel on the front of it.
great mod though. i would do the same if i didnt just order a fujita intake
Old Sep 24, 2010 | 11:13 PM
HenryLee's Avatar
^ Yea Basically what i did. I added a funnel to the tube. Will post pictures tomorrow.
