Advice needed on the Rev Ups
Old Sep 28, 2010 | 12:20 AM
240kiid's Avatar
So I Swapped my 07 VQ revup to my 03 Z which isnt a rev up.
Using an 03 ECM and the 03 Wiring harness.
Car runs but there is a bunch of codes that are on!
The is sluggish when it hits about 4k rpm
I was also wondering would it be better if i just ran a Stand alone instead of rewiring the whole thing. Cam angle sensors isnt plugged in.. Advise guys i need them!!!
Old Sep 28, 2010 | 05:48 PM
Inter_America's Avatar
you need the rev up ECU and most likely the harness as well. VVT on your original '03 VQ only works on intake valves. VVT on the rev up motor works on both intake and exhaust valves.
Old Sep 29, 2010 | 05:00 AM
240kiid's Avatar
I know I need the 07 ecu And harness but I was wondering if thers another solution. Cuz the one u just said is a pain in the ***.
Old Sep 29, 2010 | 12:58 PM
well good luck with it kid. this is what happens when you don't things right the first time.
Old Sep 29, 2010 | 04:21 PM
Canadian's Avatar
Canada, eh?
Was looking into this with my car and my 6mt swap. You'll definately no way around it need a rev up ecu, rev up engine harness, AND new wideband a/f sensors or else you'll have a code since 03s use narrowband a/f sensors.
Old Sep 29, 2010 | 04:57 PM
240kiid's Avatar
ok cool ill redo the whole wiring... thanks for the advice...
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
derres
Aug 28, 2015 03:27 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
