2003 G35 Sedan stalling out when starting car, just put in new Battery..Any Help?
Hi All,
I am new to this forum but I am having a problem with my car stalling out when starting it and I just got a new battery. My check engine light is on and my car does seem to run after giving it gas but that is not a normal way to start a car. Any ideas please will be very helpful? Should I reset my ECU?
Try this.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
Operation Procedures
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Yes they are do it yourself steps just like the dealer would do and charge you for it.
Hasanbaloch
Feb 29, 2024 08:45 PM
TWASkyliner
Feb 8, 2020 08:00 PM
